Window Replacement / Stucco Or Drivit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 05:46 PM   #1
Window replacement / Stucco or Drivit
The window I'm replacing has a putty or caulk substance on the exterior. It is a rubbery like bead, almost like glazing, sealing the brick mold to the stucco. The brick mold sticks out futher than the stucco. Unlike brick, where the brick mold is inset. Does any one know what this product is and any hints on it's application. I don't think it is silicone. Help !!!
buckwillis is offline   Reply With Quote
Old 01-18-2008, 08:49 AM   #2
Without seeing it tought to say. If its kind of a softer surface on the cured sealant, I would have to guess Vulkem. Its availible at HD. When applying it make sure both surfaces are completely dry or the sealant will fall right off. And don't get it on your clothes cuz it's there forever! Brand new black carrhart jacket smeared with tan vulkem looks awesome! Their color names are kinda goofy so buy a couple that you think are close. Good luck!
ez-e is offline   Reply With Quote
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 10:20 AM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 12:48 PM
replacement windows in stucco houser Building & Construction 3 08-22-2007 11:28 PM
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 07:33 AM
Replacement window redline Building & Construction 3 09-10-2006 07:21 PM
