Window Replacement--pvc Or Aluminum Covering The Old Wood?? Pls Help !! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 05:29 PM   #1
window replacement--pvc or aluminum covering the old wood?? pls help !!
I am replacing 2 or 3 of my house windows . House is 25 yrs old, and windows are triple pane wood. The wood is not rotten, but the paint is often peeling/bubbling from direct sunlight & rain. I can't afford to spend 10 grand on the whole house, so ...a few now (one is cracked, the other steamed).
Pvc frames...white is not going to match my current brown trim. ;( This might only be for a few yrs till the others are re-done.
Now a contractor offered to replace just the glass, and I can get the old wood covered by painted aluminum in any color now or anytime later. That solves my color-mismatch problem .
BUT..is the alum. fix (and it looks ok to me, I saw samples) as good for resale of my house in 15 yrs as the pvc would be? thanks in advance.
not a craftsman. (retired)
silvershot77 is offline   Reply With Quote
Old 05-26-2009, 05:34 PM   #2
Rewards Points: 5,336
Are you replacing the sashes and capping the frame?
Ron
Old 05-26-2009, 05:42 PM   #3
Excuse me, what are the sashes ?
Old 05-26-2009, 05:50 PM   #4
the Musigician
DangerMouse's Avatar
the sash is the framed window section itself. there are replacement sashes available.
DM
Old 05-26-2009, 06:08 PM   #5
Thanks, and yes.
Old 05-27-2009, 04:17 PM   #6
If the sash is the wood frame, no, that is part of my question.
Is it any worse off for resale to have alum. cladding over the frame than pvc framing/sash ??
Old 05-27-2009, 04:31 PM   #7
the Musigician
i doubt it, the new buyers will probably not even notice the difference.
DM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Custom Curved Window - Replacement AndrewF Building & Construction 3 01-12-2009 11:32 PM
Covering concrete stairs with wood bkcmurphy General DIY Discussions 8 01-02-2009 10:50 AM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 11:19 AM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
