Window Pane Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 09:57 PM   #1
window pane replacement
need to know how to replace an american craftsman stationary window panel
curlsenwolf is offline   Reply With Quote
Old 08-26-2010, 05:46 AM   #2
Glass units on some windows are not replaceable, you need to replace the whole sash. Not sure which American Craftsman uses.
Or are you looking for instruction to remove the sash?? There is usually a clamp of some sort that holds fixed sashes in place. It should not be hard to spot.
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 10:06 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
