Window Leak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 02:42 PM   #1
Window leak
I am wondering if anyone can make suggestions about how to find the source of a leak coming from the top of a slider style window into my house.
It only happens when it is very windy and raining hard. It is a new development that seems to have started after I had the brick moldings replaced.
I have had the window caulked repeatedly since the problem started so I don't think that would be the solution. One contractor said that a small piece of flashing on the roof near the gutter was improperly installed and may be the source, but the flashing has been like that forever.
I should probably also mention that the location of this window is near the point where the first story roof meets the aluminum siding of the two story part of the house.
I have had 3 contractors here without any success. Two were not interested in the work. I'm not sure if the job was too small or too difficult for them.
Any input on what to do and/or who to call would be greatly appreciated.
Thank you.
handyandi is offline   Reply With Quote
Old 08-04-2010, 04:40 PM   #2
kwikfishron's Avatar
Rewards Points: 618
Get out there with a hose or pressure washer and systematicly start low and slowly work your way up the wall and onto the roof if needed with someone on the inside looking.
You should find the leak.
Posting a “stand back” picture here would help too.
kwikfishron is online now   Reply With Quote
Old 08-04-2010, 06:10 PM   #3
Smile
Window leak
Thanks a lot for your help. I'll get that picture as soon as I can.
Old 08-04-2010, 07:13 PM   #4
KemoSabe
loneframer's Avatar
Pics would help, for sure. This homeowner asked me to troubleshoot a "roof leak" for him. It turns out, it was more of a siding issue and nothing to do with the roof. It's likely there could be issues that have nothing to do with the brick molding, or it may very well be the brick molding.
Three guys tried to fix that leak before I did. It's been 2 years now and the homeowner loves me.
loneframer is offline   Reply With Quote
Tags
aluminum siding , brick moldings , flashing , leaking window , window trim
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
window leak c00rdb General DIY Discussions 11 03-03-2010 06:29 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
