Window Installation Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 10:34 PM   #1
Rewards Points: 201
Window installation questions
I will be installing some windows in new construction and was wondering about the following.
When installing a flanged, new construction window in a rough opening that has 1/4" clearance on all sides, should you center the window top and bottom or should you let it rest on the bottom sill ?
Should you use nails or pan head screws in the flange mounting holes ?
I noticed that the mounting holes in the flange are somewhat slotted; should the nails or screws be tight against the flange or should there be a slight clearance for the window to move if the framing settles somewhat ?
The windows have a built in J-channel for siding, but after installation and before the siding, should you apply something like a strip of peel & stick roofing membrane around the perimeter, overlapping the flange to the sheathing ?
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 03-10-2011, 12:17 AM   #2
Rewards Points: 83
I would rest the window on the sill, and just shim one side enough to make the window sill level. Leave as much of that 1/4" gap at the top as you can. There's plenty of room to insulate the under the sill, but if you raise the window and your top gap is, say, 1/8" then it might be hard to insulate the top.
I'd use roofing nails to fasten the flange as opposed to screws. The wide nail head will hold better and they're flat. With screws you would need to sink them into the flange a bit to make them flush, and it's easy to drive them all the way through. You might use a few screws for the corners when you're shimming and adjusting so you can easily back them out, but use nails for the rest.
You should drive the nails tight. You don't want the flange to move. I have no idea why the holes are slotted and I had the same question, so when I installed my windows I called Andersen to confirm this.
-Mark
cumak is offline   Reply With Quote
Old 03-10-2011, 06:10 AM   #3
And yes to self stick flashing membrane. Start at the bottom, then the sides overlapping the bottom, then the top overlapping the sides. The top metal flashing should go on first, down over the top of the window frame and up under any housewrap, then the sticky.
Old 03-10-2011, 06:31 AM   #4
Rewards Points: 83
I agree with your comment, except the part about the bottom. You shouldn't caulk under the bottom flange, or apply flashing membrane over it. If any moisture should find it's way behind the window, you need to leave a way for it to drain out. If you caulk or flash the bottom flange it will get trapped there (or find somewhere else inside the wall to go).
Old 03-10-2011, 07:19 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
always best to lift the bottom of the window off the sill,but 1/4''clearance is pretty tight
Tom Struble is offline   Reply With Quote
Old 03-10-2011, 07:30 AM   #6
Experienced
Jackofall1's Avatar
Always best to follow manufacturers instructions to the letter, otherwise you will void the warranty. Go to the web site for the windows you bought and research the install method you will be using.
Mark
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
Vinyl window installation questions Hexar Remodeling 9 01-06-2011 07:54 PM
Window installation advice Cossack Remodeling 7 04-16-2010 01:44 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Window installation cost only. Changeling Building & Construction 18 06-30-2008 02:01 PM
