Window Installation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 06:00 PM   #1
Window installation question
Hello everyone,
When installing a new construction window is it necessary to create a draining damn on the sill? I read online about using a piece of cedar siding since its beveled and fasten to sill? If this is true should it be installed under or over the sill flashing?
mikescs is offline   Reply With Quote
Old 06-29-2013, 06:23 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,874
What type of window?
Old 06-29-2013, 06:36 PM   #3
General Contractor
CENTERLINE MV's Avatar
Not necessary if you flash properly. If you go that route, clapboard goes under flashing.
CENTERLINE MV is offline   Reply With Quote
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
jaydevries (06-30-2013)
Window flashing question markharmon Building & Construction 18 06-18-2013 05:59 PM
Window Replacement Mull Question ryanb4614 Windows and Doors 3 04-28-2013 07:13 PM
window installation in brick+framing wall amakarevic Building & Construction 9 12-24-2011 04:37 PM
Yet another window question tpagel Carpentry 1 07-21-2008 11:51 PM
Window Well Installation Bill46 General DIY Discussions 1 04-03-2007 05:49 PM
