Window Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 01:21 PM   #1
Window Installation
Hello,
I have recently had egress windows installed and the exterior finishing seems questionable by the contractor. Hoping to get some opinions on it. Looking at the picture below, should there be any caulking between the window frame and the wood trim? Is that gap normal? also there is a gap at the siding that is about 3/8" wide and it seems like water can just run down behind the siding.
Thanks!
Brian
eggcrate is offline   Reply With Quote
Old 06-14-2012, 10:23 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
water will always run/get behind vinyl and just about every other type of siding,the top j channel shoud be ''tabbed'' so water is directed into the side j [it should be directed out over the top lock at the last panel before the sill]
hopefully the unit was flashed like it says in installation instructions that were glued to the window glass
trim job looks a little diceyyou can caulk it to the window if you want but as far as water intrusion imo it's not necessary and will just become a maintenance issue
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
eggcrate (06-15-2012)
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
New Construction Window Installation SanDiego Building & Construction 1 06-16-2009 12:28 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Well Installation Bill46 General DIY Discussions 1 04-03-2007 05:49 PM
