Old 11-27-2008, 10:22 AM   #1
Tinkerer's Avatar
Window ID?
My sister has a house built 5 years ago. The latches, for the casement windows, are failing and she cannot keep them closed without me taking out the latch and manually pulling them shut. Is there a way to identify the window manufacturer to order replacement parts or would it be better to have a machinist make up sturdier replacements? The actual problem is where the latch handle attaches to the lever; it's stripped from the pressure of pulling the windows in. Once we identify a replacement solution, I plan on adjusting the latches to reduce the pressure while still maintaining a seal, but need a place for parts first. Thanks.
Tinkerer is offline   Reply With Quote
Old 11-27-2008, 10:58 AM   #2
Window ID?
look in the corners of the glass for id
skeeter 152 is offline   Reply With Quote
Old 11-27-2008, 11:13 AM   #3
Window ID?
If they're vinyl, look at the top and bottom of the sashes. Sometimes the factory labels are left on.
jerryh3 is offline   Reply With Quote
Old 11-28-2008, 11:22 AM   #4
Windowpartsguy
Window ID?
What about the builder? 5 years isn't very long and most builders (who build on spec anyway) Use the same windows etc as much as possible for this very reason, they go nuts trying to figure this stuff out later.
Is the house in a neighborhood where other people may have the same windows from that builder? Maybe they hung onto the paperwork when they bought the house, or sometimes people are a bit more lax about scraping stickers off the windows in the garage or attic etc where you may get some clue.
Also remember the hardware isn't made by the window company in almost all cases. Did you look hard at the arms that extend out to the sash for a name embossed on it. Names like "truth" are very popular. If that's all you have to go on, i guarantee you you can find a website selling this hardware that will ask you certain questions (ie measurments etc) to help you order the same hardware and circumvent the whole process of dealing with the window company.
Macattac is offline   Reply With Quote
Old 11-28-2008, 12:37 PM   #5
joed's Avatar
Window ID?
Look at the metal strip between the two panes of glass around the outside edge. They often stamp their names on the strip and it should be visible in any pane.
Old 11-28-2008, 12:53 PM   #6
Eibwen
Window ID?
I havent used em in years but try blainewindow.com.
They specialize in window hardware including obsolete stuff.
Sammy is offline   Reply With Quote
Old 11-28-2008, 02:46 PM   #7
BUILDER / REMODELING CONT
buletbob's Avatar
Window ID?
Post a picture of the window maybe someone here will identify it BOB.
False Window craleo Remodeling 1 11-18-2008 09:44 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Shower in Window jchri66 Remodeling 1 05-27-2008 01:50 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
