Window Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 12:19 PM   #1
Window Header
What size header should I use for a window header on a 2x4 wall spanning 16' with a R.O. of 30 inches?
Freej81 is offline   Reply With Quote
Old 07-26-2012, 12:56 PM   #2
Need to know where you live for a snow load calculation and what is above the window...roof...1 story and a roof, two stories and a roof...ect?
JonM is offline   Reply With Quote
Old 07-26-2012, 01:28 PM   #3
All you need to do is measure another header in your home. All of the head heights of the windows will be the same regardless if it is a 24'' header or a 72'' header.
CopperClad is offline   Reply With Quote
Old 07-26-2012, 02:09 PM   #4
Rewards Points: 2,202
we always run a double 2x10 for every header.
If it is a larger picture window say 6' or more we may go to a LVL or engineered header.
And we have high snow loads.
mae-ling is offline   Reply With Quote
framing door opening under existing window header... paredown Building & Construction 9 02-23-2012 08:24 AM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
Dormer Window header. Joe1. Building & Construction 3 08-03-2010 11:25 PM
How to drill into metal window header? BrandonDL Carpentry 4 01-29-2009 06:01 AM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
