Window Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 11:41 AM   #1
Window framing
Hello. I am new to the forum but have looked things up in the past. I am replacing 2 windows in bedrooms in my home and the wood is in bad shape. I have room to make the windows bigger and had some questions.
1. I was wondering if I can find a new construction window near the size I want and build a frame to accept it. Is there any problems with doing it this way?
2. Should I use standard or treated lumber for the frame? I will have it wrapped with aluminum once I am done.
3. The sill sloped away from the old window and I assume I should do the same. Is this correct?
4. Any reasonbly priced brands that you would recommend?
Thanks in advance for answering my questions. I really appreciate it.
JMLTS is offline   Reply With Quote
Old 09-10-2012, 11:50 AM   #2
Rewards Points: 150
No PT lumber if your wrapping in alum...and pics would help alot.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 09-10-2012, 02:32 PM   #3
Rewards Points: 2,212
Make sure you put in a new header and studding if going bigger.
mae-ling is offline   Reply With Quote
Old 09-10-2012, 09:39 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
new construction windows will have nail flanges around the perimeter of the window so the exterior siding will have to be cut back to allow for the nail flanges and then the siding put back ...
hand drive is offline   Reply With Quote
Old 09-11-2012, 12:13 AM   #5
Rewards Points: 13,752
Vinyl windows are made to size so there's no need for reframing if you just order one the same size.
Basic help with window and door rough framing danf26 Building & Construction 3 08-20-2012 10:51 PM
window jambs flush with framing porchhen9 Remodeling 3 05-15-2011 05:42 PM
Rough framing a window hwdruman Building & Construction 4 06-14-2010 09:03 AM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 09:33 AM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
