Window Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 04:01 PM   #1
Window framing
Hi guys
I Need advice on this framing. Do I need to put doble 2x6 on each side of the window rough in?
I know I need to put fireblocks but I didn't till I find out if I need another 2x6 on the side.
EHouse is offline   Reply With Quote
Old 07-07-2011, 04:19 PM   #2
Rewards Points: 5,336
You should have jack and king studs on either side of the window running from the top plates to the bottom plates. If this is a load bearing wall, you'll need a header.
If any of these terms are unfamiliar, do a goggle search so you can respond.
Ron
B. Franklin 1759
Old 07-07-2011, 04:23 PM   #3
Thx, it already have a header on top of the two top plates.
Old 07-07-2011, 05:21 PM   #4
Not in the picture you posted.
Ron
B. Franklin 1759
Old 07-07-2011, 05:33 PM   #5
It was a porch with 2 2"x12"x12' nail together between the 6x6 post and the brick wall. The room is about 12'. Can I use this and evade putting a header on top. If we put a header we are going to end with the window too low.
Old 07-07-2011, 09:49 PM   #6
Posting a photo from the outside will help determine the load.
Ron
B. Franklin 1759
Old 07-24-2011, 07:39 AM   #7
Here. The inspector came and said it's Alright but must have wind bracing.
Old 07-24-2011, 07:41 AM   #8
Thanks Ron for your help. Appreciate it.
Old 07-24-2011, 02:41 PM   #9
Registered User
Rewards Points: 5,514
May need the extra stud/blocking for interior/exterior trim or casing.... Blocking required for shear with the plywood/OSB?
Gary
Old 08-06-2011, 04:02 PM   #10
Gary
I don't think is required but I put them too, ...just in case. The most important thing said the inspector is that your 2x6 have to be nail to the OSB every 6" max. And vertical pieces.
Old 08-06-2011, 10:01 PM   #11
Too Old
When I frame in windows I always have dbl. stud on sides (kingstud and trimmer) and the sill, this helps with nailing later. Being you are framing in a porch I would still double stud around the window.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 08-07-2011, 08:04 AM   #12
Thx for your advice.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
window jambs flush with framing porchhen9 Remodeling 3 05-15-2011 05:42 PM
Rough framing a window hwdruman Building & Construction 4 06-14-2010 09:03 AM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 09:33 AM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
