Window Flashing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 07:51 PM   #1
Window flashing question
Hi guys,
I have a question. Sometimes I guess two different answer from people I talk to so I figured I would ask here. When installing a new construction window and you plan on having a rigid foam or fanfold insulation should the window be installed before or after the foam? My thinking is that you want to incorporate the flashing with the house wrap, therefore, the window would have to be installed before the foam but then some people are saying they would install the window after the foam insulation. What do you think?
markharmon is offline   Reply With Quote
Old 06-15-2013, 11:21 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
you keep asking this question and we keep giving the same answer. install the window on top of the foam.. otherwise you will have to install a trim detail so the siding has something to butt up to.
for the flashing if i you put house wrap on top of the foam, just flash the window normally and have the house wrap lap over the flashing
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (06-16-2013)
Old 06-15-2013, 11:50 PM   #3
Shouldn't the house wrap be attached directly to the sheathing?
Old 06-16-2013, 09:53 AM   #4
Rewards Points: 140
if you are using XPS, is house wrap even needed ?
Fix'n it is offline   Reply With Quote
Old 06-16-2013, 10:23 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
It is cheap insurance Fix'n it.
And it should go over the XPS.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
oberon (06-22-2013), woodworkbykirk (06-16-2013)
Old 06-16-2013, 11:18 AM   #6
Maryland
The WRB should be installed on the same plane as the window flanges.
http://www2.dupont.com/Tyvek_Weather...h_Bulletin.pdf
Video: http://youtu.be/d9XCwC-RuTk
Pittsville is offline   Reply With Quote
Old 06-16-2013, 12:49 PM   #7
Would you just staple the house wrap to the foam or cap nails?
Old 06-16-2013, 12:56 PM   #8
Maryland
Cap nails for sure.
Old 06-16-2013, 01:48 PM   #9
Rewards Points: 854
Cap nails for sure.
+1
make sure they are long enough to get through the foam and into the studs/sheathing.
There is debate over whether you wrap the WRB into the opening vs leave it over the top of the flange but that is for a longer conversation.
Old 06-16-2013, 10:39 PM   #10
Registered User
Rewards Points: 4,912
Drainage plane under the foamboard on both "innie" and "outie" windows; http://www.buildingscienceconsulting...se_Studies.pdf
Just be sure to add shims/slope at sill first; Fig.9; http://www.buildingscience.com/docum...d-wall-systems
Where are you located? What type of siding? Any rainscreen? What brand of housewrap? Any poly vapor barrier under the drywall?
Gary
Old 06-17-2013, 08:06 AM   #11
Rewards Points: 854
Gary
We would all love to have the budget that the BSC does when doing their wall details.
Most folks will not have the adhered layers at the sheathing plane in these type of retrofits.
Old 06-17-2013, 07:37 PM   #12
So, if you do have some type of foam insulation then you can install right over the sheathing then housewrap then make the cutout for the window then install your flashing tape on the sill and over the flanges? Doing an innie window would be installing the window on same plane as the sheathing and your foam would be installed over the window flanges? If you did that then I would think you need some type of aluminum trim on the insides.
Old 06-17-2013, 08:32 PM   #13
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Rather than install the windows on top of the foam, why not add an extra layer of sheathing (maybe 4" wide pieces) around the window opening and then butt the foam board up to that. That would give you something more solid to nail the windows to.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-18-2013, 07:53 AM   #14
Rewards Points: 854
We usually do build SIP bucks around the windows for just that reason.
Old 06-18-2013, 04:20 PM   #15
by doing that you lose the thermal break between the framing and the window unit.. . you simply go to a longer siding nail and use hurrican straps when installing the window
flashing replacement window tom31415926 Windows and Doors 23 06-29-2012 10:01 PM
2x6 window header question MoneyPit3 Building & Construction 12 04-02-2012 03:01 PM
New Window Question Underdog Windows and Doors 1 06-22-2011 10:23 PM
Flashing question where eavestrough meets stucco wall? chadurban Roofing/Siding 3 12-31-2010 06:42 PM
