Old 02-15-2010, 02:44 PM   #1
Window Flashing with Metal Siding
I've read a lot about the proper way to flash around a window/door with vinyl siding, but haven't seen much for metal siding. The big trick I'm seeing with vinyl, is to be sure the flashing at the bottom of the window overlaps the top of the last full piece of vinyl, giving the water a place to escape from behind the siding. Since this isn't an option with metal siding (meaning vertical sheets), whats the trick to make sure water isn't getting behind the siding?
vtboy51 is offline   Reply With Quote
Old 02-15-2010, 02:47 PM   #2
Tom Struble's Avatar
as long as the flashing is outside the wrb you should be ok that where the primary protection is
Tom Struble is offline   Reply With Quote
Old 02-15-2010, 02:50 PM   #3
So basically any water that gets behind the siding, will drain between the typar wrap the siding?
Old 02-15-2010, 02:55 PM   #4
yes,very efficantly what are you doing along the bottom? j channel?transition? leaving it open? if you use a trim make sure the leg that goes up the wall is under the paper
a few drain holes drilled in j channel if thats what you are useing wouldn't hurt
Old 02-15-2010, 02:57 PM   #5
I'm leaving it open, so I guess the water will just drain out.
Old 02-15-2010, 06:00 PM   #6
there ya go
whats the BEST window flashing? 4just1don General Discussion 3 06-07-2009 08:47 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
Lock for metal casement window? Casey421 General Discussion 1 09-16-2008 06:47 PM
Window Sill flashing? sandyman720 Building & Construction 6 08-06-2007 10:24 PM
