Old 08-22-2010, 02:33 PM   #1
window flashing
I had replacement windows installed and the trim covered with aluminum. The flasing on the top of one of the windows now sits back behind the edge of the trim about 1/4 inch.We had a pouring rain for about 12 hours and I noticed water leaking in the basement below the window on the exterior wall. Is it possible that the water wicked in through the top and ran down behind the trim? I caovered the whole window with plastic and now the leak has stopped.
hitmehhh is offline   Reply With Quote
Old 08-22-2010, 03:39 PM   #2
Tom Struble's Avatar
window flashing
pic?...
Tom Struble is offline   Reply With Quote
Old 08-22-2010, 04:48 PM   #3
window flashing
window flashing-dscn2087.jpg This is the right side that is the worst. The water seems to be on the left side but is likely running across.
Old 08-22-2010, 04:56 PM   #4
window flashing
hard to tell but the new drip cap may be just an L shape thats slid under a pretty poor example of a drip cap and that could cause your problem
Old 08-22-2010, 05:14 PM   #5
window flashing
Yeah, that is the original window flashing and the new trim is tucked under it. I just realized I hve another leak on a window on the same side of the house . Drenching rain just won't quit. I will have to get up there when rain stops and check both windows. The one window the flashing does come out beyond the trim. Maybe a caulk problem on the trim.
Old 08-22-2010, 05:27 PM   #6
Mod
kwikfishron's Avatar
window flashing
How long ago were they installed?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 08-22-2010, 05:32 PM   #7
window flashing
A year ago and never had a problem until today.I"m calling the installer tomorrow but I just wanted some other input just to see what others might think.
Old 08-22-2010, 05:43 PM   #8
Mod
window flashing
What did they do, pull out the old wood windows, slide those in with no nail flanges and screw them in from the sides?
-NEW MEMBERS-
Old 08-22-2010, 05:49 PM   #9
window flashing
Yes ,they're replacement windows and they screw in through the side rail.
Old 08-22-2010, 06:01 PM   #10
window flashing
window flashing-dscn2089.jpg This is a finished window. Everything seems buttoned up. I think the water is getting into the trim somewhere.
Old 08-22-2010, 06:14 PM   #11
Mod
window flashing
Yep, that’s the fast way to do it for sure.
The problem is with that type of install caulking is about your only defense from the weather.
Once a year you should inspect the caulking for separation and touch up or replace if necessary.
They look nice though.
-NEW MEMBERS-
Old 08-22-2010, 06:19 PM   #12
window flashing
So you think maybe where the trim meets the house?The way he bent the trim it comes 3/4" onto the face of the window so the only caulk is where the trim rails meet the sill and where the trim rails meet the siding.
Old 08-22-2010, 06:22 PM   #13
Mod
window flashing
As Tom said it’s hard to say.
If I was troubleshooting it I’d use a hose to figure it out.
-NEW MEMBERS-
Old 08-22-2010, 06:25 PM   #14
window flashing
That was my thought. Thanks guys.
Old 08-22-2010, 06:27 PM   #15
Mod
window flashing
There’s no caulking where the trim meets the window on the sides and top, only the sill?
-NEW MEMBERS-
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Window Flashing compromised Rubu Building & Construction 4 10-09-2008 05:39 PM
