Old 11-03-2009, 09:55 PM   #1
Default Window Drip Cap- To Caulk or Not?
I just replaced the exterior trim and storm windows in a couple of windows. I saw that the aluminum drip cap at the top of one of this window was so heavily caulked between itself and the cedar clapboard resting on top of it. Could that be why water sometimes leaks inside my window from the top? that the water collecting inside the drip cap had no place to go if its all caulked up?
I have removed most of the caulk and may also need to replace the one clapboard in question, as its kind of damp and soft. There might be rust or a hole in the aluminim that's causing the water leakage after a heavy downpour.
My question is, after I put in a fresh piece of clapboard over this drip cap, do I need to add any caulk to this drip cap, underneath it where it meets the top trim, or where the clapboard and cap meet, or none at all and just leave it open? I will be caulking the sides where the siding meets the vertical trim.
Thanks for your help
greg
gam7 is offline   Reply With Quote
Old 11-03-2009, 10:29 PM   #2
ArmchairDIY's Avatar
A photo would help, but if I understand correctly, yes caulking should be used there.
Is it possible you are getting water in from higher above some place?
"It looked good on paper, but paper is funny that way"
ArmchairDIY
ArmchairDIY is offline   Reply With Quote
Old 11-04-2009, 01:49 PM   #3
tomstruble's Avatar
never caulk between the siding and the dripyou can however caulk the drip and the trim under it
tomstruble is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking the caulking on our doors and windows. What you want to do is take a look at the joints where your window meets your house. At that seam there should be caulking and you... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be talking about caulking the seams. Now that we have replace all of our new siding on our house and we have securely attach it we need to go through and put caulking on all of the... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be caulking our seams. Now that I have my new trim board on I need to go back and put caulking in all of the seams as well as all my metal. This is really going to help prevent any... Read More »
Okay, our next step for painting the kitchen is to fix all of these cracks that are occurring along the edge of the trim. And we do that with the caulking. So let me show you how to get that started. You want to keep a pail for clean up because it gets... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be checking our chimney. Now if you have a chimney that is brick or block, you are going to want to check the mortar to make sure that none is loose or deteriorated or any missing... Read More »
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
Recaulking at previously silicone-caulked shower door frame hffeagan General Discussion 21 07-24-2009 02:42 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 10:14 PM
Condensation on Metal Window Frames: Should I Caulk? xquercus General Discussion 6 06-29-2007 11:24 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
