Old 11-05-2009, 08:18 PM   #1
Default Window DP ratings
Shopping for windows for an addition. I live in coastal NC and am wondering about what DP rating to get. Any help or leads would be appreciated.
Brown Dog is offline   Reply With Quote
Old 11-06-2009, 07:47 AM   #2
DP rating????????????
Old 11-06-2009, 09:35 AM   #3
gravity always wins
DP=Design Pressure. How much wind pressure the window will sustain before failure. Sort of a hurricane resistance rating. The higher the DP number, the more sustained wind the window will resist. Seems to me that If I was in coastal hurricane land, I'd go as high as I could.
Old 11-06-2009, 07:22 PM   #4
Are you looking for impact resistance as well as specific DP?
Do you know what windzone you are in?
A simple formula for converting windspeed to DP is to divide the DP by 20 and the square the result.
For example, assuming a windspeed of 120:
120/20 = 6. Square 6 = 36. So a DP of 36 is equivalent to a windspeed of 120mph.
Keeping in mind that windows are tested for structural at 150% of DP and for water infiltration at 15% of DP, there may be other issues for you to consider.
Have you talked to your local code folks for their recommendations?
oberon is offline   Reply With Quote
More On This Topic
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
Digital Performer is a product of the Mark of the Unicorn company and I am in no way associated with Mark of the Unicorn. OK, what we're going to explore in this tutorial are work flows and workflow environments. I work in OS 10 which is the Macintosh... Read More »
Digital Performer is a product of the Mark of the Unicorn company and I am in no way associated with Mark of the Unicorn. Good afternoon. Today we're going to be discussing digital audio workstations and digital audio work stations are for music... Read More »
Hi I am David Belch with Expert Village and today I am going to show you how to install windows. In order to completely finish the window you check for square. This window of course a new stop had to be replaced and we will have to caulk and paint the... Read More »
That shed or garage in your backyard may have more uses than just storing tools or that old car that hasn't run in three years. With some work and design skills, it could be converted into an extra residence to use as either a guest house for visitors or... Read More »
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 10:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 12:47 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 06:49 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
