Window Doesn't Close - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 05:42 PM   #1
Window doesn't close
Apologies if this is in the wrong sub-forum, but it seemed to be the best fit.
Our house (1930's rowhome, gutted in 2004 by previous owner) has the same vinyl double-pane windows throughout. The 2004 rennovation was done acceptably, but the work was generally sloppy, if functional. We have been in the house about a year, and during that time the front window has not been able to latch. The top pane and the bottom pane can go to their respective places, and it gets close enough that the latch can sort of friction hold it together, but it's not seated properly in the groove it should be to lock the window. This is a bit of a security problem, as you might imagine (not that a fully latched latch would be terribly secure, but it's better than nothing).
The window frame looks like it's seated properly (at least without ripping out the drywall), and this is the same window as all the others in the house, so presumably they work just fine. I'm at a loss for what might be going wrong or how to fix it. Any ideas are welcome.
Thanks!
gsk3 is offline   Reply With Quote
Old 09-16-2009, 05:13 PM   #2
Rewards Points: 5,336
It could be that the window is not square in the opening. Basically the window is a rhombis, not a rectangle.
Close the window and look at it from the outside. If one side is touching the bottom sill and the other side has a gap, the window was installed improperly. You would need to reinstall the window to fix the issue.
Ron
Old 09-16-2009, 07:45 PM   #3
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Not an easy way to figure this out without physically seeing/handling the window,but a couple of possible fixes;
Try pushing the top sash up with a little more force.Sometimes,depending on the type of replacement,they will get hung up on the upper frame.
Look for obstructions in side channels where the valance is,maybe the screw to secure the window to the frame is backed out.
Check the sill and header to make sure there are no bows in them.Put a straight edge on them for checking.
Also check each sash for same.
Make sure the pin for the pivot point of the sash during tilting is securely imbedded in the mechanism.
If you see something that doesn't look right,come back and post what you find.
oldfrt is offline   Reply With Quote
Old 09-16-2009, 09:50 PM   #4
Ron
I'll go take a look. Hopefully it's something else, so I don't have to rip out the whole thing :-/
Old 09-17-2009, 09:01 AM   #5
also try measuring from corner to corner if they are not the same its not square
clasact is offline   Reply With Quote
Old 09-17-2009, 10:21 AM   #6
That's a good trick. I'll do that. Thanks.
Casement window doesn't close all the way jasontal Building & Construction 1 08-23-2009 09:23 PM
Window won't close completely bucksone General DIY Discussions 3 06-25-2009 06:57 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
