Window Clearance To Proposed Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 10:17 PM   #1
Rewards Points: 248
window clearance to proposed wall
I want to create a non load bearing wall inside a house. It connects like the letter T with a current load bearing wall close to a sliding glass window. How far away from the sliding glass window does the T connection need to be? I mean what is the minimum recommended and minimum code clearance between a window and a non load bearing interior wall?
jackwashere is offline   Reply With Quote
Old 01-25-2013, 10:22 PM   #2
Rewards Points: 13,458
Got a picture drawing, something?
No code I know of just have to have enough room for the casing. The more room you leave the easer it will be to finish the drywall.
Old 01-25-2013, 11:30 PM   #3
Rewards Points: 6,652
Figure from the corner, a stud with some blocks for spacers between it and the corner, should work. Drawing of the plan helps, to know what you are dealing with, along with pictures. If you do the blocks from the corner, that would give you aprox. 5 1/4 inches with 2x4 blocks. If you use 1x4 blocks as spacers, that would give you 4 1/4 inch clearance from the corner.
Old 01-25-2013, 11:34 PM   #4
skk
leaving enough space for casing and more would be good.
I would think of the practicality of mudding, painting etc
skk is offline   Reply With Quote
Old 01-26-2013, 12:08 AM   #5
They really only need about 2" from corner to window frame. That would mean just one 2x4 for the corner, and would allow for casing. Figure from inside edge of window framing to corner, about 3 1/4" total.
Window in basement wall Bigin429 Building & Construction 0 03-05-2012 08:36 PM
Window sill recess 4 a brick wall RedBear Building & Construction 0 07-17-2011 09:53 PM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 05:32 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
