Window Casings Around Window With Integrated J Channel? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2007, 07:12 AM   #1
Rewards Points: 152
Window casings around window with integrated J channel?
Hi All,
Can a window that has an integral J channel have casings built around it?
sandyman720 is offline   Reply With Quote
Old 09-28-2007, 12:34 PM   #2
Can you post a photo of the integrated j-channel/window?
redline is offline   Reply With Quote
Old 09-28-2007, 01:13 PM   #3
Rewards Points: 152
Here we go.....
Old 09-28-2007, 01:34 PM   #4
Rewards Points: 790
YES. I accidentally ordered a window last spring with a J-channel return. Having brick mould on my other windows and since I wasn't planning on residing my house anytime soon, I added the brick mould. It looks great. Just make sure you caulk any seams, so water does not penetrate.
cibula11 is offline   Reply With Quote
Old 09-29-2007, 03:38 PM   #5
edited: I miss understood the original post, I thought we were bricking the house.
97catintenn is offline   Reply With Quote
Old 09-29-2007, 08:35 PM   #6
Rewards Points: 152
Hi 97. I never said that I was making this brick. This is going to be vinyl siding.
I am asking about the window trim not the siding.
Old 09-29-2007, 10:25 PM   #7
Okay, after reading the post below yours about brick mold, I thought that was direction you were going. My mistake.
So, you want to trim around the window with casing and still be able to install the siding, right? This is beyond my skills or knowledge. I wish I had some helpful advice.
Old 09-30-2007, 07:34 AM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
You could rabbet one side of the trim to fit into the j-channel and rabbet the other side for vinyl siding to fit in. Kind of like a J-channel extension. What brand windows do you have? Could you post a closer picture of the j-channel?
Nice job on the house wrap and window flashing.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-30-2007, 12:10 PM   #9
Are you trying to match up casing that is on the rest of the house?
If so, could you post a photo of the other windows that have the casing that you would like installed on these newer windows?
Old 09-30-2007, 07:06 PM   #10
Rewards Points: 152
THanks Clutch!
I have Certainteed Brynmawr II. (sometimes called New Castle).
Any experience with these?
Old 10-01-2007, 08:24 PM   #11
It's nice to see they got the Tyvek right.
Yes you can add whatever trim you like. Just make sure that on the top of the window you put drip cap under as well as above any trim you use and caulk the entire perimeter of the window.
jiggyjack is offline   Reply With Quote
Old 10-02-2007, 01:15 AM   #12
Check out the thread I started in the Building and Construction forum called "Hardiplank and New windows". There are some really good photos of examples of just what you are asking about here.I did mine this way.
white29 is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
I blew it on the mesurements.Vinyl window Doug Crf Remodeling 6 03-29-2007 10:06 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
