Old 06-29-2011, 11:37 AM   #1
will these fit in my 2x4 wall??
i'm trying to install a recessed soap niche and was wondering if this will fit?
http://www.flooringsupplyshop.com/sh...ecess-462.html
my 2x4s measure 3 1/4 across and it seems like there isn't any recessed niches that fits my bill.
the recess linked is a 3.5 depth according to this chart.
thanks.
vote4Pedro is offline   Reply With Quote
Old 06-29-2011, 11:47 AM   #2
Add your drywall into the equation, and they look fine to me.
DexterII is online now   Reply With Quote
The Following User Says Thank You to DexterII For This Useful Post:
DangerMouse (06-29-2011)
Old 06-29-2011, 11:52 AM   #3
Since this items is "ready to tile" I assume you're putting it in as part of building/tiling a tub surround? If so, put up the cement board first - that will give you half an inch more depth.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 06-29-2011, 12:31 PM   #4
what should i used to seal off the joints with the durock?
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
Replacing load bearing wall KarlJay Building & Construction 3 01-05-2011 05:03 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
