Will This Subfloor Support A Pool Table? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2013, 09:17 PM   #1
Will this subfloor support a pool table?
I'm working on the plans to finish my basement and am leaning toward the 1" foam with 3/4 OSB or Plywood over top option.
The pool table is about 1000 pounds.
What do you think? am i going to have a crushed floor?
Also- i live in Chicago and wanted to insulate the floor, otherwise i would probably not do a subfloor.
Thanks for any advice.
ryanmcl is offline   Reply With Quote
Old 01-10-2013, 09:21 PM   #2
Rewards Points: 13,300
If you used blue foam and Advantec subflooring I see no reason it would not work.
Old 01-10-2013, 09:30 PM   #3
Thanks. Any idea what a 4x8 sheet goes for? Doesn't look like they show pricing online.
I have a 1200 sq ft basment and dont want to break the back.
And yes, 1" blue board under.
Old 01-10-2013, 10:18 PM   #4
No clue, last time I bought it, it was lower then CDX.
Make sure it's T X G.
Old 01-10-2013, 10:28 PM   #5
and i would just tapcon that to the floor right?
Old 01-11-2013, 09:38 AM   #6
Rewards Points: 29
1000lb pool table divided by 4 legs is 250 lbs per leg. The feet on most pool tables usually spreads out a bit to spread the load. So in reality, it is not much different than a 250lb person standing there.
cube17576 is offline   Reply With Quote
Old 01-11-2013, 09:45 AM   #7
When I did it I used 1/2 blue foam and 3" long Tap Cons. Floor does not move at all and the screws grabed great.
Unless you can find screws longer then 3" I'm not sure if they would hold with that thick a foam.
The 1/2" was enough to give me a theramal break and it really made the floor warmer.
Old 01-11-2013, 12:13 PM   #8
How thick was your top layer? Did you use advantec?
Old 01-11-2013, 12:52 PM   #9
Rewards Points: 150
ryanmcl,
One other factor to consider is the floor joists spacing. Is your floor joist spaced at 16" or 24" O/C?
There is some science in physics behind the answer to your question and concern.
oodssoo is offline   Reply With Quote
Old 01-11-2013, 03:54 PM   #10
Not so new
12penny's Avatar
Rewards Points: 520
It's a basement. No joists involved.
12penny is offline   Reply With Quote
Old 01-14-2013, 01:38 AM   #11
Looks like im going to move forward with 1" xps and 3/4" adventec T&G. Thanks for the assist.
Filling in our InGround Swimming Pool wnewman Landscaping & Lawn Care 17 04-22-2013 08:27 AM
Painting / Refinishing a pool table dannydizzan Painting 9 08-07-2012 02:44 PM
pool table clearance pyper Remodeling 12 04-27-2011 07:08 AM
pool table over garage....can floor take the weight james6097 Flooring 1 04-19-2011 09:01 PM
Pool Table on Floating Hardwood Q......... tigerbalm2424 Flooring 4 07-28-2008 09:09 AM
