Will Caulk Dry Outside In Cold Weather? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 02:27 PM   #1
Rewards Points: 260
Will caulk dry outside in cold weather?
I need to caulk where my gutter meets my downspout, but I'm afraid it won't dry in the cold. Does anyone know if it will dry in the cold? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 01-18-2011, 02:42 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
depends what kind of caulk are you using?don't use a water or acrylic based caulk if you know freezing temps may happen before curing
actually if you read the tube it will say what conditions you can use it in
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
jpearson311 (01-18-2011)
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Cold weather is here, looks like time to start a fire Scuba_Dave Off Topic 78 10-03-2010 11:21 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Sealing stone outdoors in cold weather newhomebuilder Flooring 1 01-18-2010 07:31 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
