Will A Building Inspector Tell Me If A Wall Is Load Bearing? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 12:59 PM   #1
Rewards Points: 264
Will a building inspector tell me if a wall is load bearing?
Or will he just tell me to have a structural engineer look at it?
tibberous is offline   Reply With Quote
Old 08-25-2011, 01:04 PM   #2
Rewards Points: 5,336
I don't know why he would take on the liability.
Ron
B. Franklin 1759
Old 08-25-2011, 01:08 PM   #3
Rewards Points: 264
Guess I just wasn't sure what his role / training was. You'd think he'd need some kind of background in engineering, otherwise how would he know what to pass?
Old 08-25-2011, 01:16 PM   #4
He inspects what he sees to make sure it satisfies the building code and looks at the approved plans if he has any questions.
There are inspectors on the site. Hopefully they'll give their take on the subject.
A local contractor should be able to tell you. If you want to take some photos of the room, maybe we can help.
Is the wall parallel to the ridge line?
Parallel to the main beam in the basement?
Do the ceiling joists rest on the wall?
Do the joist in the basement and in the attic run in the same direction?
Ron
B. Franklin 1759
Old 08-25-2011, 03:54 PM   #5
Too Old
I would be surprised if an inspector would tell you if it was a load bearing that is not his job, but if you want to get on the bad side of one just call him out to have a look. Calling a contractor would be much better being that is what they do.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
load bearing wall question mudpaws Carpentry 3 06-24-2011 10:39 PM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 08:12 AM
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
