Width Interior Doors-code? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 01:24 PM   #1
width interior doors-code?
Is there a width for interior doors to meet code? In finishing the basement, it looks like the doors at the bottom of the stairs will be only 28" due to having to put sheetrock over the concrete next to the previous openings. There is an egress door and window.
canoes is offline   Reply With Quote
Old 02-18-2012, 01:28 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Exterior doors, utility room, elevator doors: 3, bedroom: 2'-8", bath, 2'-4". That's it in MO.
titanoman is offline   Reply With Quote
Old 02-18-2012, 01:48 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
R311.2 Egress door. At least one egress door shall be provided for each dwelling unit. The egress door shall be side-hinged, and shall provide a minimum clear width of 32 inches (813 mm) when measured between the face of the door and the stop, with the door open 90 degrees (1.57 rad). The minimum clear height of the door opening shall not be less than 78 inches (1981 mm) in height measured from the top of the threshold to the bottom of the stop. Other doors shall not be required to comply with these minimum dimensions. Egress doors shall be readily openable from inside the dwelling without the use of a key or special knowledge or effort.
This may help.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-18-2012, 03:09 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
canoes -
The codes are just the minimums to keep you out of jail.
When you want to move furniture, especially appliances and mattresses, you may think about just going with the code minimums and not being practical.
Dick
concretemasonry is offline   Reply With Quote
Old 02-18-2012, 09:04 PM   #5
So it sounds like if the main door to the outside is 32 and I have egress windows, the doors up to the stairs will not be a code violation even if they are smaller than I wanted.
We had to take furniture up the outside stairs even with the old wider doors due to sharp turn.
Old 02-18-2012, 09:09 PM   #6
Registered User
Termite's Avatar
That is correct. Interior door width is not specified in the IRC code.
Old 02-19-2012, 12:22 AM   #7
Framing Contractor
All you have to do is call YOUR building department and tell them what you are doing and ask them. How come you haven't done that?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-19-2012, 08:22 AM   #8
Quote: All you have to do is call YOUR building department and tell them what you are doing and ask them. How come you haven't done that?
Because they are hard to reach-I've tried with other questions. It's a small county and the 2 guys are usually out doing inspections and I wanted to know before the doors go up.
Old 02-19-2012, 08:44 AM   #9
Framing Contractor
You have no choice but to ask them before the doors go up because if you install the wrong doors...when they come to inspect it...you will have to rip them out.
Joe Carola
Old 02-19-2012, 08:59 AM   #10
Crusty Old Dude
Big Stud's Avatar
Personally ..... I put in the biggest doors possible regardless of where they are.
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 02-19-2012, 10:12 AM   #11
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
locally a 2'4" door is the minimum allowed for a interior door which leads into a room though this size door is extremely rare to install now.. i run into them on renovations when only the slab is being replaced.. if we are stripping off walls to expose framing i will change the framing to be a minimum of 30"
doors can be smaller than this but they are for closets, or double doors or bifolds which are taken apart and hung as a normal door only doubled
woodworkbykirk is offline   Reply With Quote
Old 02-19-2012, 01:19 PM   #12
Disabled wood vet
titanoman's Avatar
Exactly.
Old 02-19-2012, 06:35 PM   #13
Thanks for the feedback. I would have loved to have larger doors, but we would have needed to alter the stairs for that. Working with the previous layout has been a challenge for the doors and the bath.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-13-2012 11:07 PM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
