Width Of Fireplace Wall W/ Brick & Mantel - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 09:13 PM   #1
Rewards Points: 274
width of fireplace wall w/ brick & mantel
I am in the process of building a house. The plans call for a 36" prefab fireplace on a 5' wide bump out wall. I would like a raised brick hearth and brick surround with the basic painted white mantel w/ legs. I don't think I have enough room for the brick surround and mantel on a 5' wall do I...??? I need all the room I can get because I am planning on putting cabinets/shelves on both sides of f.p.
ugabulldog is offline   Reply With Quote
Old 07-19-2010, 10:10 AM   #2
Rewards Points: 5,336
The fireplace unit has clearances listed in the instructions. What do they say?
Ron
Old 07-19-2010, 02:21 PM   #3
Rewards Points: 274
Ron
They say 1' min clearance for combustibles....but the pictures on their website definetly don't show 1' between fp and mantel.....I was hoping someone would chime in that had the set-up or has built the set-up I am looking at.....the surround doesn't have to be brick, it can be black slate w/ wooden mantel w/ legs but most of the mantels I see online are wider than 5'...??? Is my plan not going to work???
Old 07-19-2010, 02:24 PM   #4
Pictures in brochures don't trump directions or building codes. Have you contacted your local building department?
Ron
Old 07-19-2010, 04:20 PM   #5
Rewards Points: 274
Ron
Actually after looking at another spec sheet from a different manuf. it allows combustible material 1/2" from outside of fireplace (of course i would have non-combustible until where mantel starts), I knew all the pictures can't be wrong......so m y question is one of asthetics,......I guess I can figure out I have 1' on each side of 36" fp going w/ a 5' wall,.....is this enough for a surround of some sort and a mantel w/ legs??? or would it look/be too tight???? thanks if anyone can help
Old 07-19-2010, 10:16 PM   #6
Mock up the scenario in cardboard and see if it looks okay.
Ron
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Run wire to Breezeway through brick and up brick wall wad2k Electrical 0 04-16-2010 09:18 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Re-Facing Fireplace Wall with Veneer bamatide Building & Construction 1 06-06-2009 04:14 PM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 09:22 AM
