Widening Patio Entry 1/2 Inch To Replace Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 05:59 PM   #1
Widening patio entry 1/2 inch to replace door
Hi,
I have an old sliding patio door that is getting harder to open over time. Looking to replace with a standard size french patio door. The problem is the opening is the right height, but the width is 1/2 inch too narrow. The french patio door I am looking at cost about 350.00, but I am told I have to order a custom door costing 1600.00.
Looking at the sides of the entry there are three vertical 2 by 4's on each side. Is this a crazy thought to remove one of the boards from each side and shim it up minus the difference to create the 1/4" space on each side to accommodate the less expensive door?
Directly above the door is a horizontal support 14 feet wide with three more vertical supports.
The basic description of the back exit to the house is a siding back door with a window on each side, and above the 14 foot wide horizontal part are 4 windows spanning the 14 feet.
Is this a reasonable work around to ask a contractor to do? If this can be done I would think its less expensive than going for a custom door if it was done right. I do have some concern this home depot contractor is trying to get me to pay more so he can get a higher percentage.
Thanks for any thoughts and even if this can be a diy job, I have another contractor that will assist me in doing this if possible. But I have not even asked about this type of modification to anyone.
Thanks!
Kel
kozy is offline   Reply With Quote
Old 08-24-2011, 06:28 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't need a custom door, that's ridiculous. The door you want can be made to fit.
I'll let one of our local carpenters tell you the best way to do it.
So...why can't he answer your/this question?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
kozy (08-24-2011)
Old 08-24-2011, 06:38 PM   #3
Too Old
Not sure if I understand correctly but it sounds like you have a 14' header maybe? if so the the 3 - 2xs would be trimmers and you should have no problem removing 1 on each side and filling in to get the 1/2" you need.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
The Following User Says Thank You to havalife For This Useful Post:
kozy (08-24-2011)
Old 08-24-2011, 08:09 PM   #4
Rewards Points: 6,652
How did you measure? Is the old patio door and frame already out of the opening? If it isn't, I bet that you will find out that the opening is correct, once you get that old door out.
The Following User Says Thank You to gregzoll For This Useful Post:
kozy (08-24-2011)
Old 08-24-2011, 09:27 PM   #5
Thats what I figured but needed some backing. The Home Depot contractor measured and stated it was 1/2 " too narrow. I never did get to talk to him directly, I wasn't home during the visit. The other contractor who did some work in the past has a standing offer to assist me on any project I do but has not been called upon for help. Thanks!
Old 08-24-2011, 09:28 PM   #6
That is correct!
Old 08-24-2011, 09:30 PM   #7
Home Depot measured it. I talked to a friend tonight who said the exact same thing! I have a feeling you may be correct. We will see the day we pull the old one out!
Old 08-24-2011, 11:04 PM   #8
That is why myself and most others do not like these so called "contractors" for the big box stores. I ran into about the same problem, when we were shopping for storm doors for our house. The contractor said that both doors were out of plumb, which really our back door is, due to was never flush when whom ever installed the door, did not take the time to make sure it was plumb & flush with the house.
The only real way to measure while that door is in, is to pull the moulding off around the door, and measure then at three points horizontal, and three points vertical. As for your old door, it could just be that the rollers are needing replaced. Once you get the old one out, give it to your local Habitat for Humanity store, since someone may be able to use the unit in some project they may be doing, and in turn you get a tax write off.
How to replace a patio door Franky Building & Construction 2 09-24-2010 06:21 AM
patio door installation question gintaras Building & Construction 3 01-20-2010 10:32 AM
Deck repair, oops replace, oops new patio door thread drtbk4ever Project Showcase 19 09-16-2009 09:20 PM
Old 80" wood entry door replacement janralix Carpentry 5 08-18-2009 12:02 PM
