Widen A Cupboard Door Frame - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2010, 04:00 PM   #1
Widen a cupboard door frame
Hi
I have a cupboard about 7ft long with the door in the middle, I'd like to have easier access to each end of it so widening the door frame to have either sliding or folding doors seems the obvious answer. The wall enclosing is plasterboard. Would it be possible to just cut the existing plaster to the width required and replace the frame for the door/s?
sallyc is offline   Reply With Quote
Old 02-06-2010, 08:44 PM   #2
Rewards Points: 5,336
Originally Posted by sallyc View Post
Hi
You can widen an opening, but how you do it depends on the structural load above. You would need to determine how the structure is set up.
Ron
Old 02-07-2010, 03:27 PM   #3
Ron
Hi Ron,
Thanks for speedy reply. I don't think it's a support wall as the only thing it appears to support is a plasteboard cornice, which is stuck on the outside of cupboard on to the plasterboard wall. Looks as though the cupboard was put in decades after construction of flat, so would that mean it's not a load bearing wall? I'm a total novice at this type of diy and any info greatly appreciated.
Old 02-07-2010, 04:30 PM   #4
Hi Ron,
Pictures would help.
Is a cupboard a food pantry? Walk in? or like a closet? Is there a floor above this? Can you see the floor or ceiling joists anywhere in the house?
How old is the house?
Ron
Scratched kitchen cupboard doors in need of help nottinghamfella General DIY Discussions 1 12-05-2009 04:48 AM
Anything wrong with putting an electrical box in a kitchen cupboard beech Electrical 8 10-05-2009 05:24 AM
Under cupboard lighting Ste Meds Electrical 3 11-07-2008 08:46 AM
bedroom cupboard to shower room? woodland81 Plumbing 5 07-08-2008 09:25 AM
Widen a doorway Oilerz Remodeling 3 01-06-2008 08:31 PM
