Why These Same 6 X 2's Weigh Different? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 12:44 AM   #1
Rewards Points: 682
Why these same 6 X 2's weigh different?
I recently bought 4 pieces of 6 X 2 lumber, 10' long. I've noticed that 2 of them are much heavier than the other two, even though they are the same dimensions, and both are douglas fir.
The heavier pieces look older and whiter. The lighter pieces are redder and look newer, cleaner.
Does anyone know why this should be the case?
darsunt is offline   Reply With Quote
Old 02-04-2011, 06:10 AM   #2
Old growth wood of a given species is denser(tighter rings) than farmed wood of the same species.
Old 02-04-2011, 11:35 AM   #3
Contractor - Renovations
fungku's Avatar
I'd think heartwood vs. sapwood (different parts of trees) could have different densities as well.
Also moisture content can play a big role in weight.
fungku is offline   Reply With Quote
Old 02-04-2011, 04:22 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Ayuh,... It's Wood,.... No 2 boards are Exactly the same....
Kinda like Snowflakes,... Which I've got Plenty of at the moment,...
Old 02-04-2011, 11:24 PM   #5
fungku's Avatar
ain't that the truth.
nearly all the products with any real consistency and predictability are man-made/engineered
but natural stuff has it's own beauty
Old 02-04-2011, 11:55 PM   #6
Registered User
Rewards Points: 526
The new ones are lighter because they are drier. As 2x6's are kiln dried, the moisture is removed to stabilize the wood from twisting and warping later. 15-19%, I think... The older ones have absorbed moisture from the air and gotten heavier because of the water as they have been out of the kiln longer.
My 2 cents....
Gary
how much does concrete weigh? nap Building & Construction 20 11-20-2009 01:01 PM
how much does the head of a 5 lbs sledgehammer weigh turtlekiller82 General DIY Discussions 6 09-15-2009 10:05 PM
How much does 200' of triplex weigh?? 4just1don Electrical 3 05-05-2009 09:18 PM
How much does 5/8 drywall weigh? sedwick Building & Construction 12 10-07-2006 04:20 PM
