-   -   Why fill the basement back in with dirt? (http://www.diychatroom.com/f19/why-fill-basement-back-dirt-101558/)
nateshirk 04-14-2011 10:12 PM
2 lots down from mine, they started another house. But they're building it differently than mine was built. They dug the hole, built a cynder block foundation (as opposed to poured walls). Foam boarded all the walls. Then filled it back in with dirt. Why would they fill it back in?
<*(((>< 04-14-2011 10:33 PM
They backfill the wall to provide increased support to the foundation. This prevents the wall from buckling towards the inside of the footprint of the house.
nateshirk 04-14-2011 10:57 PM
So they'll dig it back out?
Ron6519 04-15-2011 08:06 AM
Maybe there's no basement in this house. Doesn't make sense(to me) to fill in the hole to redig it out. If the builder was concerned about pressure, he would have capped the foundation with the first floor framing platform to stabilize the foundation.
Ron
Red Squirrel 04-15-2011 08:20 AM
Sounds like a bad plan. A house without a basement will have trouble selling. If they went all the trouble to make a foundation they may as well do it right. I'm suspecting they lazied out and did not put any drainage so if they kept the basement it would always have water issues. IMO best to just do it right while they're at that step. Easier now then after.
tcleve4911 04-15-2011 08:29 AM
............go down the street and ask 'em.......
Willie T 04-15-2011 08:36 AM
Why do we so often overlook the simplest answers?
oh'mike 04-15-2011 09:12 AM
I've got two neighbors who filled in the basement before the house was built.
Both houses are within 300 feet of the river----both flooded after the footings were put in--High water table.
nap 04-15-2011 09:26 AM
did they pour a floor inside of the walls though? If not, it may have simply been that they felt they had to go that deep to build a proper foundation and the house was designed for a crawlspace type foundation.
If they poured a floor, I have no explanation for what they did. You would never want to do that. You would have to have a means for the crawlspace to drain.
Leah Frances 04-15-2011 12:40 PM
It's CHEAPER.
concretemasonry 04-15-2011 12:57 PM
With bad surface soil or high water levels it is possible to see a "double" foundation built. The first half is built to put in the strip footings and build the block walls to the right height and then fill with concrete sand (definitely not "dirt")and build the "upper" foundation that will be seen and the floor of that is poured after the utilities are plumbed. The house is just built on top of the second "foundation".
Block is use because they do not know in advance what the real height of the lower foundation is because general soil borings do not always provide the accurate information that is gotten during excavation and the height and steps can be adusted easily. Makes no sense to go deeper than necessary.
Dick
nateshirk 04-15-2011 11:21 PM
Can't just "ask em'". I have a job. When I get home, they're already done for the day.
They now stoned over the dirt and pipes protrude out of the stone, so I can only assume they're not going to have a basement. Seems weird In my area though.
And I'm nowhere near water.
joed 04-15-2011 11:49 PM
Could it be a garage where they need the support for weight? Seems odd that they would dig it all out and then fill it. Usually they would only dig the trenches for the foundation.
jomama45 04-16-2011 08:09 AM
Are you sure they didn't just leave the center "hump" in place and dig the trenches out?
How tall are the walls, 4', 8'?
AllanJ 04-16-2011 02:04 PM
Does the complete house have but a crawl space under it or is there a full basement with the entire house raised over it?
