Why Does This Contractor Need To Know Where My Footings Are? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 09:25 AM   #31
yummy mummy's Avatar
Rewards Points: 1,016
Originally Posted by jogr View Post
He's trying to figure out how deep he can go that close to your footing before the dirt supporting your footing collapses. That's what he means by the angle of repose. Depending on soil type there is an angle he shouldn't exceed or much unhappiness will ensue.
Yes, I agree, much unhappiness will ensure, and much more money on his part.
Does it not have to be inspected by the building dept. before footings are done?
yummy mummy is offline   Reply With Quote
Old 08-04-2010, 03:30 PM   #32
They have stopped digging, and I have noticed today that the contractor was there with some guy with the house plans in front of them. The contractor asked me if my basement floor was all one level, which it is.
I am wondering as to what affect does this have on my foundation since they have stopped digging? I can see some ground water. They have dug approx. 2 1/2 feet away from my foundation wall.
Are they not disturbing the soil around my foundation as it is empty now?
Thank you.
I will be contacting the contractor tonight regarding my concerns, and possibly calling the city inspector.
Old 08-04-2010, 03:36 PM   #33
Concrete & Masonry
Rewards Points: 470
How much lower than your foundation wall, or footing even, are they? I wouldn't go assuming the worst yet based on the facts that you mentioned.
jomama45 is online now   Reply With Quote
Old 08-04-2010, 05:16 PM   #34
If you can post a pic that might help too
So all of the dirt between your house & where they are digging is gone ?
Old 08-04-2010, 06:17 PM   #35
Here are some pics that I have taken. They have just dropped off a pile of gravel? Is that what it is called? Little pebbles......lol
Thanks very much.
Old 08-04-2010, 07:14 PM   #36
Concrete & Masonry
Rewards Points: 470
Everything looks fine to me, it looks like good, stable soil. It appears the excavator is a good operator as well. From these pics, I'd say you can expect a drier basement in the future. Maybe you'll owe these guys a beer by the time they're done...........
Old 08-04-2010, 08:49 PM   #37
Registered User
Rewards Points: 4,912
Not to upset you. What are the two pieces of pipe in the picture, pink looking, one is under water, the other sticking out of the dirt, like drain tile..........
Be safe, Gary
Old 08-04-2010, 09:00 PM   #38
The only concern I have is that the front part of the house is only 4.5 inches away from property line and I am certain that he will be digging lower than my footings.
Here is a pic of the front part of house.
Old 08-04-2010, 10:05 PM   #39
Old School
Willie T's Avatar
Speaking seriously for a minute, the Angle of Repose is a highly critical consideration in excavation here in Florida where we have mostly sand.
Many times we are required to drive deep "sheet pilings" along side an excavation such as they have dug next to your house to contain and restrict any shifting of the supporting soil beneath your footings....... or from the edge of a steeply sloping lawn or cliff-like topography..... and especially from the edge of a waterfront property line.
In most cases the angle here is 45 degrees. (Not to worry. It is obviously MUCH less where you are.)
In other words, if the bottom of your footing is four feet down, we cannot disturb the soil within four feet of your house's footing edge without initiating protective measures. The stipulations also begin to exacerbate in restrictive encroachment distances with deepening excavation. It is an engineering thing, but I think the A of R actually reverses as you pass the bottom of an adjacent footing, and of course, progressively widens as the digging depths increase. I'm not well educated in these things, so I do what the guys who are say I am supposed to do.
Thus.......... the sheet pilings are used to segregate the two properties till the digging can be effectively replaced with fully supporting (compacted) soils.
Willie T
Old 08-04-2010, 11:43 PM   #40
Concrete & Masonry
Rewards Points: 470
Be safe, Gary
Gary, I think that they are merely remnants of the draintile from the existing neighboring property. If YM has draintile that is running across the neighbors property, that's her problem to deal with IMO, not the home builders, or especially the excavaors.
The Following User Says Thank You to jomama45 For This Useful Post:
Gary in WA (08-05-2010)
Old 08-05-2010, 12:47 AM   #41
Be safe, Gary
They are remnants from the demolished house.
Old 08-05-2010, 12:51 AM   #42
Willie T, they have not installed anything. In fact they have not completely excavated. The blocks that you see are still from the old foundations of the previous home.
Old 08-05-2010, 09:43 AM   #43
Old School
Willie T's Avatar
Well, as I said, we live on mostly all sand down here. It is one of the most solid foundation soils possible.... BUT it can easily migrate if not contained somehow.
Where you are, you likely don't have that problem. From the looks of it, they could probably go another foot closer to your house with no problems.
Willie T
Old 08-05-2010, 02:54 PM   #44
Thanks Willie T for your help.
We are speaking with the contractor tomorrow regarding this issue.
He said that he is taking all the necessary precautions regarding my footings and foundations. He stated that he is doing block foundation and he will be back filling by hand.
I think i may contact the building inspector for a second opinion on it.
Old 08-05-2010, 03:06 PM   #45
Old School
Willie T's Avatar
Idealy, they should be running a compactor across the backfilling at every 8". But no more than at layers of 12" between compaction passes. A really conscious contractor will just have a man in the ditch the whole time running the compactor. Might be something you want to keep an eye on.
Sounds like you have a good man to work with there, but it never hurts to keep an eye on things.
Willie T
Concrete Footings for a Detached Garage??? canyonbc Building & Construction 76 11-17-2016 11:23 AM
footings for 6x6 post ugabulldog Building & Construction 4 06-27-2010 09:24 PM
Drywalling down to cement footings Jettech Remodeling 4 03-07-2009 03:20 PM
footings vs pylons smarbaga Building & Construction 1 03-26-2008 10:53 PM
