Why Does This Contractor Need To Know Where My Footings Are? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2010, 11:13 AM   #16
yummy mummy's Avatar
Rewards Points: 1,016
Originally Posted by forresth View Post
maybe he just want to make sure you basement floods before the new one does
3'11"? don't you both need a bit more offset than that?
I am one foot away from property line. My home was originally built in 1942, and we gutted and renovated, and kept that wall standing so we did not have to move the required 4 feet from property line when building.
yummy mummy is offline   Reply With Quote
Old 07-31-2010, 01:15 PM   #17
Tizzer's Avatar
Rewards Points: 460
But why is the neighbor building so close to the line, are the lots that small?
A French drain is a ditch/trench filled with gravel to redirect water. This should explain it.
http://en.wikipedia.org/wiki/French_drain
Tizzer is offline   Reply With Quote
Old 07-31-2010, 01:27 PM   #18
My last house was built with part of it OVER the property line
Former owner had to buy a triangle of land from neighbor to make it legal to sell
Old 07-31-2010, 03:24 PM   #19
Registered User
Rewards Points: 526
The main reason to dig 2' farther is to have room setting the footing forms and the excavator machine operator doesn't want to come back if undersized. They may hand dig when close to your footings. Ron gave some good advice. Usually these operators are professionals and know what they are doing. I think Dave is giving you needless worry, but keep an eye on them enough not to distract them....
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
jomama45 (08-01-2010)
Old 07-31-2010, 07:31 PM   #20
Yes, the lots are rather small, and at a premium. Both mine and the neighbours are 30 feet by 125 feet.
Old 07-31-2010, 07:32 PM   #21
Thanks y'all for all your great help and suggestions.
I will keep an eye on it for sure.
Old 08-01-2010, 12:39 PM   #22
Concrete & Masonry
Rewards Points: 620
I will echo that if you have any concerns at some point, take a few pics and post them here for comment.
If the neighboring basement ends up lower than your's (very likely), your basement should end up much drier, which is always a plus.
jomama45 is offline   Reply With Quote
Old 08-02-2010, 05:00 PM   #23
Thanks, I did not know that. Yes, drier is great.
Old 08-02-2010, 05:02 PM   #24
I was told, he is checking to find out the repose angle......whatever that is.
The Following User Says Thank You to yummy mummy For This Useful Post:
Willie T (08-04-2010)
Old 08-02-2010, 06:12 PM   #25
Rewards Points: 5,336
Many contractors like an afternoon nap, especially the ones over 60.
Ron
Old 08-02-2010, 06:48 PM   #26
Ron
Hahaha......they guy is only about 40.......
Old 08-02-2010, 06:49 PM   #27
Registered User
Rewards Points: 526
Probably trying to figure out if there is enough room on the lot for the excavated dirt, without hauling it all out, then some back: http://en.wikipedia.org/wiki/Angle_of_repose
Your basement..... maybe he's a visual kind of guy.....
Be safe, Gary
Old 08-02-2010, 10:11 PM   #28
Rewards Points: 1,910
He's trying to figure out how deep he can go that close to your footing before the dirt supporting your footing collapses. That's what he means by the angle of repose. Depending on soil type there is an angle he shouldn't exceed or much unhappiness will ensue.
The Following User Says Thank You to jogr For This Useful Post:
Old 08-03-2010, 04:39 AM   #29
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Thanks to GBAR for for the Repose Link
Very interesting and with the bonus note on the sand trap
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-03-2010, 08:22 AM   #30
Be safe, Gary
Thanks for the link.
Concrete Footings for a Detached Garage??? canyonbc Building & Construction 76 11-17-2016 10:23 AM
footings for 6x6 post ugabulldog Building & Construction 4 06-27-2010 08:24 PM
Drywalling down to cement footings Jettech Remodeling 4 03-07-2009 02:20 PM
footings vs pylons smarbaga Building & Construction 1 03-26-2008 09:53 PM
