-   -   Why does this contractor need to know where my footings are? (http://www.diychatroom.com/f19/why-does-contractor-need-know-where-my-footings-77512/)
yummy mummy 07-30-2010 01:13 PM
There is a house being built next door to mine. They are digging the foundations today.
The contractor came over and wanted to go down to my basement to measure from the floor to the ceiling to find out where my footings are.
Why does he need to know that?
The are digging fairly close to my house.
I am curious as to why that matters.
Thanks you wonderful folks.
Scuba_Dave 07-30-2010 01:27 PM
How close is very close ?
If they dig too close, and deeper then your footings......
it could undermine your house...usually in a rain storm
Only thing I can think of.......
Ron6519 07-30-2010 01:41 PM
Maybe this is his first foundation and he needs a hint or two.
I'd speak to the neighbors to make sure they have a permit and that
the contractor has all the needed insurance.
If he doesn't, I'd make a call the whoever controls this before this guy starts digging.
Ron
DexterII 07-30-2010 01:57 PM
On the other side, if he happened to ask if you had any water problems in the basement, he may have been simply wondering what to expect when they dig the footings. Not a very good reason to go into someone else's home, particularly without an explanation, but some people simply weren't in school the day that they taught manners. Regardless, the reason previously mentioned is probably more likely, so, regardless, I definitely agree with ensuring that the proper permits and insurance are in place, and, in fact, under the circumstances, I would ask for a certificate direct from his provider.
PaliBob 07-30-2010 02:46 PM
yummy, Thanks for asking
As others have said you are justified in being suspicious as to motive.
I would first ask him for his card. After you get it, ask "Did you have to get a permit?". If the answer is negative, give him an excuse and usher him out. Then call your local Building Authority.
Keep us informed.
Proby 07-30-2010 02:50 PM
Why not just ask him???
yummy mummy 07-30-2010 04:46 PM
Thanks for all your responses. They do have a permit to build the house. I was advised of the home by the building dept.
When I asked him, he simply said that he "just wants to know".....:eek:
He is probably old school, and figures, what does she know anyway.....
Scuba; The new wall of the house will be 3' 11" away. Obviously they have to dig wider, and then back fill. They are very close.
I have asked about insurance and he says that he is covered. He is a registered contractor, I have checked that out.
I am concerned about rain. What should I tell him about possible rain?
Thanks again, you guys are the best.
Ron6519 07-30-2010 05:24 PM
If the wall is that close and he has to drop forms, I would think there would be no soil between the 2 foundations until he back fills. You need to keep tabs on your outside drainage and any foundation waterproofing you have. The system, if disturbed and not corrected, could effect your house. I would keep a dailey video or photographic diary of the process. If any damage is done, I would immediately bring it to the contractors attention. not to the help, directly to him. You might also inform the building dept overseeing the job.
Ron
PaliBob 07-30-2010 06:01 PM
First you have to get ID because if the situation goes sour you need documentation.
BigJim 07-30-2010 06:16 PM
Maybe he was wanting to see if any pipes were coming into your house from that side. One more thing to watch is if you have a french drain on that side of your house, he may damage it or destroy it being that close.
Ole Jim
Proby 07-30-2010 07:22 PM
Wow, that explains it. 3'11" is close, his work can seriously effect your home. I hope he had all the utilities for both houses surveyed and laid out? Check your basement wall to be sure nothing is coming in on that side.
A daily video taping is a great idea.
Scuba_Dave 07-30-2010 08:56 PM
When they poured my garage foundation they dug about 2' beyond where the forms were set up
yummy mummy 07-31-2010 08:52 AM
Ole Jim
What is a french drain?
yummy mummy 07-31-2010 08:55 AM
OMG! I am keeping an eye on it for sure, since they are so close.
forresth 07-31-2010 11:14 AM
maybe he just want to make sure you basement floods before the new one does:thumbsup:
3'11"? don't you both need a bit more offset than that?
