Why Do We Bring Water Into Our Homes? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 02:48 PM   #16
Rewards Points: 736
Originally Posted by jomama45 View Post
I don't think it's necessarily a "stupid question". If it was, I don't know why there would be regions of this very country where it was common to put sump crocks on the exterior.............
Actually, the fact that we bring exterior water into are basements as fast as possible is puzzling to alot of people. Until I've explained how the entire system works to customers, many of them have asked similar questions of me in the past..............
Are you only talking about new construction? Maybe that's my confusion.
Because plenty of people have sump pumps in their home because despite their best efforts to keep water out, it's getting in anyway.
TheBobmanNH is offline   Reply With Quote
Old 03-15-2013, 10:09 PM   #17
Rewards Points: 4,656
water flows down alongside the bsmt walls because bldrs never or rarely place & compact backfill in ' lifts ' either out of laziness, ignorance, or being cheap bldrs,,, a few yrs back, toll brothers used rub-r-wall for their fnd coatings & would guarantee dry bsmts for 10 ( TEN ) yrs,,, other jabonies used cheap asphalt emulsions & offered the same but when bsmt problems occurred, didn't honor their warranties,,, did you know home warranties only cover wet bsmts for the FIRST year ?
anyway, 2 responders used their noggins tnx, jomama & dick
Old 03-15-2013, 10:19 PM   #18
blew this 1
Old 03-15-2013, 10:21 PM   #19
there is no waterstop between the footer & bsmt wall & typically only a 3mil dampproofing coating,,, think of your basement as a ship's hull below the waterline & its much easier to understand,,, the ONLY time to wtrproof is PRIOR to backfill,,, after that, its all water management
even in MY house 3 sided conc block bsmt walls sitting on a conc footer,,, i can see signs on the lower course of wtr - in MY house
yes, it IS personal but that's life
we routinely excavate condo walls, properly wtrproof them, put in toe drains, hdpe fabric wall protection, sumps, pumps, & then backfill,,, tallest standpipe so far's been 10',,, 30 in the last 5 yrs w/no callbacks nor complaints from adjoining condo's, either IF i were concerned about pump freeze, its easy enough to add a sump heater OR 150w elec light to the circuit
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
