Why Are Crawl Spaces Vented? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2006, 03:40 PM   #1
Rewards Points: 83
Why are crawl spaces vented?
I have an old house with full basement that has an 13x24 addition put on the back of it a few years ago. This addition has a crawl space.
I just bought the house a few months ago and even when it gets colder, like in the low 40s, you can definetly feel the colder floor in the addition (even through the carpet). I live in upstate NY and am worried about how much worse they are gonna get when we get the inevitable 5 degree days here in a month or two. The crawlspace does have insulation although it is only R19-and there is a vapor barrier put on the ground. What purpose does venting the crawl space serve...would it be bad for me to close the vent for the winter?
Thanks for the replies!
Nick
AllGoNoShow is offline   Reply With Quote
Old 11-09-2006, 04:22 PM   #2
MLO
Seems like the idea of "venting" the crawl space is very debate-able.
Obviously if there is moisture present occasionaly it does need to find a way out. But if the home is built according to sound building and perimeter drain methods, what purpose do the vents serve?
What if the air outside has a higher moisture content than the crawl space? Seems the vent would be a negative.
My brick home was built in the 50's with a concreted crawl space. I have no vents and the underside of the house is imaculate and well preserved. We are now doing a remodel and code sai's I have to install crawl space venting. I'm a little miffed being I have no current issues, and installing vents in the side of a brick wall is neither fun or asthetically pleasing to me.
Would love to hear from some experienced tradespeople on this topic as well...
MLO is offline   Reply With Quote
Old 11-09-2006, 04:52 PM   #3
I cannot give you an honest answer as to why vents are code, but I have had them on 3 houses from Ohio to Florida to Arkansas. I always close the vents in the Winter and open them in the Spring.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-09-2006, 05:00 PM   #4
747
registered
747's Avatar
Rewards Points: 534
I have a crawl space and as stated above i open vents in summer and just closed them about a month ago.
747 is offline   Reply With Quote
Old 11-09-2006, 05:02 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I'm a real estate broker, and have run into house inspections with "crawlspace vents not meeting code" (too high, too far apart, etc.).
I have been told that crawlspace vents are required to "vent excess moisture and drain floodwaters".
Well, duh, me.
Seems like that would allow it to run both ways...in as well as out.
The air moisture, coupled with the ground moisture, here on Albemarle Sound in northeastern NC is very high. To prevent constant condensation dripping from my crawlspace plumbing and HVAC ductwork, I had to install a 10" louvered exhaust fan in the crawlspace door that runs 24/7. Works like a charm.
I turn the fan off and close all vents for freezing winter weather season only. My problem solved.
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-09-2006, 05:11 PM   #6
General Contractor
In the winter you can close the vent. You are right about the debate going back and forth about crawl space venting. In my opinion if you put a 4 mil vapor barrier down and attach it to the foundation walls to be air tight there is no reason for a vent. But this is just my opinion and I don't write the code. The real problem arises later when someone goes into the crawl space and punctures the vapor barrier, by mistake.
The only way to omit the openings all together is by mechanical ventilation.
Hammatime is offline   Reply With Quote
Old 11-09-2006, 05:18 PM   #7
MLO
Hammatime, I would love not to have to punch holes in my brick walls for vents. Is there a mechanical system that is somewhat rationale to retrofit into a home, could you supply any details?
Old 11-09-2006, 05:33 PM   #8
General Contractor
MLO, if you are adding an addition you will already be putting an access hole in your existing foundation to the new crawl space. Put the mechanical ventilation in the new crawlspace, so it draws from the old crawl space. The best thing to do would be to ask the building inspector what your options would be and tell him your concerns.
Crawl Space under house bobbyfrommaine Building & Construction 1 07-10-2007 09:56 PM
Crawl Excavation Doc52 Building & Construction 8 01-18-2007 07:19 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
'Earthy' smell in house from crawl... HilleMary Building & Construction 5 08-30-2005 10:13 PM
