Why Can't Anyone Cover A Mound Of Dirt Properly? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 06:15 PM   #1
Why can't anyone cover a mound of dirt properly?
I've never seen a tarp around a mound of backhoed dirt that stayed put in the wind. You dirt coverers need a better technique.
Dorado is offline   Reply With Quote
Old 05-12-2013, 07:45 PM   #2
chitownken's Avatar
Rewards Points: 510
That's because nobody makes mound shaped tarps.
chitownken is offline   Reply With Quote
Old 05-13-2013, 07:45 AM   #3
Rewards Points: 3,130
Around here, nobody covers such mounds of dirt at all. But the wind doesn't blow much either.
Old 05-13-2013, 02:07 PM   #4
MJ Force's Avatar
Rewards Points: 150
This problem has been around for thousands of years and has never been properly addressed. I know that cavemen would use sticks and leaves to protect their mounds. Short of bringing the mound inside next to a warm fire, I usually secure the leading edges with sacrificial dirt to help prevent the covering from lufting and the odd stone place strategically over the surface. You want to create a lower pressure under the tarp but is difficult to achieve since the mound is shaped like an airfoil, which in turn creates a lower pressure above the tarp thus sucking the tarp off the mound
I've gained most of my tarping techniques from my sailing days. Essential you want to create "dirty" air above the tarp or like a stalling effect on an airfoil or sail. Try this out and report back to us.
MJ Force is offline   Reply With Quote
The Following User Says Thank You to MJ Force For This Useful Post:
gregzoll (05-13-2013)
Old 05-13-2013, 08:44 PM   #5
Lord of Slums
Rewards Points: 1,974
Dirty air, I have a whole city of that and my tarps still blow off.
mj12 is offline   Reply With Quote
Old 05-13-2013, 09:19 PM   #6
Roofmaster
Rewards Points: 2,172
A Professional dirt Coverer. What heights some aspire to.
Sounds like a course of study from the U of Phoenix
A Master of Mounds Degree: MOM "Hey Mom, I just received my MOM "
The Following User Says Thank You to jagans For This Useful Post:
Old 05-13-2013, 09:31 PM   #7
Rewards Points: 6,652
Because you don't. Only city slickers and people with OCD, cover dirt mounds.
The Following User Says Thank You to gregzoll For This Useful Post:
jagans (05-13-2013)
Cover for artesian well? bw77 Plumbing 6 11-28-2011 07:06 AM
Patio Cover Design Question? Rclancyc Building & Construction 3 10-04-2011 02:07 PM
Garage Drain Cover matt151617 Plumbing 5 08-09-2011 08:56 PM
Radiator Cover Fix zetti1102 Carpentry 5 03-10-2010 11:31 AM
