Who Sells Prebuilt Roof Trusses? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 11:39 PM   #1
Who sells prebuilt roof trusses?
can i buy them at Home Depot or some place simular? my size is kind of custom: 22' wide with a height of 3ft in the middle. preferably the most economically priced.
jk333 is offline   Reply With Quote
Old 10-22-2008, 12:24 AM   #2
Registered User
Termite's Avatar
Even if you can buy them at a box store, don't. I practically guarantee you that they're incapable of providing the guidance and support you need when ordering a truss, which is an engineered product. They're probably more than willing to sell them and act like they know what they're doing though. All you're doing by going to them is adding a (stupid) middleman between you and the producer.
Many lumber yards (not hardware or home improvement stores...real lumber yards) are a good source for them. Nobody will have them in stock, they're made to order. My first stop would be the phone book. There are probably truss manufacturers in your area that would sell directly to you or through a distributor lumberyard.
Old 10-22-2008, 12:57 AM   #3
ok, so go through a lumberyard, makes sense and probably alot cheaper too. Thanks
Old 10-22-2008, 10:31 AM   #4
Drywall contractor
Rewards Points: 1,070
Like Termite said, try the phone book first. I know of two truss mfgrs. within 15 miles of where I live. Deal direct and save the middleman cost. If none around, then go to the lumber yard.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-22-2008, 02:59 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
And make sure you get the engineering data sheet from the truss manufacturer. It will list the design loads for the top and bottom cords as well as the bracing requirements. Another advantage to buying local is that they will be familiar with the snow load and seismic requirements for your area and can make sure the truss meets code. Many building inspectors will want to see the engineering sheet just for that reason.
Old 10-22-2008, 04:36 PM   #6
Drywall contractor
Good point.....not much call for snow or seismic specs here, but I'd want a copy of the engineering data anyway.
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 09:47 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
