Old 03-17-2007, 10:12 PM   #1
Who makes the best stud sensor?
The last stud sensor I bought was basically junk. I've finally decided to purchase a descent stud sensor. Now all I need is a little advice. Which brand/model should I purchase. BTW, detecting A/C is definitely a plus and something that I'd like this device to do.
kcrossley2 is offline   Reply With Quote
Old 03-17-2007, 10:40 PM   #2
fhi vinyl windows
fhivinylwindows's Avatar
Zircon http://www.zircon.com/SellPages/Scan...sor/MS/MS.html
I use the multi sensors, the AC detection is a must!
fhivinylwindows is offline   Reply With Quote
Old 03-17-2007, 11:20 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There are alot of brands out there, but I 2nd that vote....
- Build Well -
Old 03-18-2007, 12:06 PM   #4
Power Gen/RS Engineer
Zircon, without a doubt. Although I have upgraded to the super-cool top o' the line model with built in display and coffee maker, every time I cannot find it, I reach for my older, stripped-down model and am amazed at how great it works (which is why I've never parted with it).
The new one shows you where the center of the stud is, not the edges. Being the skeptic that I am, I tried my friend's out before buying my own. I actually screwed a scrap 2x4 to some scrap sheet rock and to my suprise, it was dead nuts accurate.
My house is vintage 1911 and the Zircon behaves quite well on plaster walls, even with some minor undulations. In fact, my attic is filled with vermiculite (don't go there) and believe it or not, the Zircon is capable of distinguishing the difference in density between the ceiling joists and insulation, even through plaster! Granted its operation in this instance is somewhat better than marginal but under the circumstances, that's pretty good!
So all in all, I really cant stand Zircon products.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 03-19-2007, 10:09 AM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
NOT Craftsman. I bought one of their fancy ones and it was junk. Returned it and bought a $5 Stanley and it works just fine.
Brik is offline   Reply With Quote
Old 03-19-2007, 10:23 AM   #6
So true. Had one about 5 years ago....it ended up in little pieces after about 1 hour of frustrating use....
- Build Well -
Old 03-19-2007, 12:31 PM   #7
fhi vinyl windows
The key feature on the Zircon is the AC detection. After cutting a few live wires "that did not belong" where I was cutting I knew I needed one.
Best reasonable stud finder??? Sellncars Tools 6 10-03-2006 09:29 PM
Comfortmaker makes noise on start up JHIDS HVAC 2 03-04-2006 12:41 AM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 08:24 PM
flame sensor tbristolb HVAC 3 04-10-2005 10:06 PM
