Old 12-26-2009, 07:46 PM   #1
White poly under concrete ?
Anyone against the white poly on one side for the bubble insulation for under concrete slab ? Everything Ive read thus far says that the lime in the concrete will eat most bubble foil materials and thats what the one side of poly is for. I was going to use it for what little R-value it will have but also as a moisture/vapor/radon break. Any other products I need to consider ?
Mudball is offline   Reply With Quote
Old 12-26-2009, 08:25 PM   #2
Remodeling Contractor
Better to use 6 mil black poly but you can use the white
Old 12-26-2009, 09:29 PM   #3
Moderator
Rigid foam board (2") insulation around perimeter (Or as local Building Department requirements) and air seal the plastic: http://www.100khouse.com/2009/06/24/...b-air-sealing/
Don’t use loose sand in certain applications: http://www.stellarcontractors.com/as...loose_sand.pdf
Be safe, Gary
Clothes taking longer to dry?
Old 12-26-2009, 10:31 PM   #4
Thanks for the responses and the links. Great information.
This link shows two examples of the products I was talking about.
http://www.buyfoilinsulation.com/und...ation-c-8.html
Old 12-26-2009, 11:49 PM   #5
Moderator
I'm not entirely familiar with that product but suggest you research it more. Foil needs an air space to insulate, not touching: "Underslab insulation is typically of the polystyrene board type where R-values greater than R-1.5 are specified. Reflective foil insulation, on the other hand, requires an air space to be effective although some foil products are approved for underslab applications. R-values on these products are generally R-1.5 or less." From: http://www.radiantpanelassociation.o...cfm?pageid=420
1-4" of dead air space in a wall cavity is R-1. 2" of the pink foam is R-10.
http://www.greenbuildingtalk.com/For...c/Default.aspx
This I found with a short search: http://www.healthyheating.com/Page%2...o_bldg_sys.htm
Be safe, Gary
Old 12-27-2009, 06:09 AM   #6
Interesting that you put the sand on top of the poly DPM. We put the sand below the poly to cover the hardcore.
The insulation is also put between the slab and wall now, as this is an older diagram.
stuart45 is offline   Reply With Quote
Old 12-27-2009, 07:55 AM   #7
Well very interesting indeed. I have been reading and researching for the last 1-1/2 hours since I read your posts. In short I can say that Im now 99.99% sure we wont be using bubble foil under the concrete slab.
Thanks for the help.
Old 12-27-2009, 01:45 PM   #8
stego 15mil vapor barrier's the current spec by architects/engineers
itsreallyconc is offline   Reply With Quote
Old 12-27-2009, 07:12 PM   #9
Oh yes itsrealltconc. Ive come back to the yellow stuff a couple of times. Ive already called them last week and they have given me two different suppliers in my area. I will give the suppliers a call this week. I just hope I dont get sticker shock $$$$
Thanks for the help
Old 12-27-2009, 10:55 PM   #10
Concrete & Masonry
Thanks for the help
Don't worry, you will.
Far more expensive than 6 mil poly in my experience. Unless you have a known radon problem, I'd steer towards the 6 mil.
jomama45 is offline   Reply With Quote
Old 12-27-2009, 11:32 PM   #11
Moderator
http://energy.cr.usgs.gov/radon/rnus.html
Be safe, Gary
Old 12-28-2009, 10:54 PM   #12
Thanks for the help and the link. I bought a roll of the stego 15 mil today for 225.00 and that was worth it to me. It is 2.5 times as thick as the 6 mil and when you take the 94.00 I paid for the 6 mil (94 X 2.5 = 235) then it comes close to the same or actually a little better pound for pound for what your getting. I feel much better with this product under the slab.
Thanks again.
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
