White Mortar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 08:17 AM   #1
White mortar
I am going to repoint a brick wall and use white mortar. Don't know the correct amount of white cement and lime to put into the mix.
honey95@ptd.net is offline   Reply With Quote
Old 05-20-2011, 07:40 PM   #2
Rewards Points: 582
It depends on what colour you want and if you are trying to match existing mortar. It also depends on the type of brickwork. For example older, soft bricks should normally be re-pointed with lime mortar. Some mixes use a 50/50 white/grey OPC to get a different colour.
For newer brickwork a 1/1/6 lime/cement/sand mix is often used. Stronger mixes are sometimes used in exposed areas near the coast, and with very hard engineering bricks.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
honey95@ptd.net (05-21-2011)
Match mortar jskamm Building & Construction 3 06-07-2009 03:01 PM
Bond strength of mortar??? figs Building & Construction 7 06-06-2009 04:23 PM
Removing mortar bed Cosmo Brown Flooring 2 04-05-2009 12:54 AM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 09:24 AM
Trim - White or off-white? hellothere123 Painting 7 10-31-2008 12:29 AM
