Old 08-03-2006, 01:43 PM   #1
Whirlpool Tub
Hi , I am remodeling my bathhroom and would like to replace the old cast iron tub with a whirpool. My joist are 2 X 8 and they span for 15ft, will this whirlpool be okay? Thanks..
helpless handyman is offline   Reply With Quote
Old 08-03-2006, 04:46 PM   #2
Master Craftsman
Big Dave's Avatar
Whirlpool Tub
I would say not. Code around here stipulates that a 2x10 can only span 7 feet when used as a floor joist. If it is a crawl space then go under the house and shore up under the area for the tub or better yet install a couple of beams under the joist the full length of the house to bring it up to code.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 08-03-2006, 10:13 PM   #3
Whirlpool Tub
I understand Dave, but the entire house is made of 2 X 8, 1st floor and second floor, and they all span 15ft.
Old 08-04-2006, 06:41 AM   #4
Master Craftsman
Big Dave's Avatar
Whirlpool Tub
You never said but are you replacing with the same size tub only a whirlpool or are you wanting to but a bigger one in? If you are replacing with the same size you should be fine as the whirlpool will weigh the same or less than the cast iron. Think about where the tub is. Is it close to an outside wall or over a wall downstairs? If so you could probably upgrade to a bigger tub. As long as it isn't in the middle of the 15' span you will probably be ok.
Dave.
Old 08-04-2006, 08:53 AM   #5
Whirlpool Tub
Thanks Dave, actually I replacing it with the same size (32 X 60) and its fiberglass, the tub that was there was cast iron and it weight a ton... Its going to be installed right by the exterior wall, where the joist come out of the wall, maybe a 5ft span. Thanks again! Hey Dave, I got a post on stairs in Carpentry, can you take a look at it? Thanks!!
Whirlpool tub doesn't work Scott_K Plumbing 15 05-04-2012 08:12 PM
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 07:33 AM
Whirlpool tub mathmom3 Plumbing 2 11-14-2008 02:51 PM
whirlpool ed25tqxfn01 woodyw Appliances 1 03-06-2008 01:37 PM
tile step into whirlpool ekaplan1020 Remodeling 1 04-09-2006 11:48 AM
