Old 03-03-2008, 03:47 AM   #1
Where to put Septic Tank?
We have a plot of land that is narrow (16meters) but long (100m) To enter the land you turn off a main road & drive up a steep hill to get to some flat ground, we want to site a house just behind the hill on the flat. Can we place the septic tank in front of the house? That is, dig out a bit of the hill and place it there, it would just be easier to get at for maintenance. Are there rules that state it would have to go behind the house? This info might help us with siting the house before we submit for Outline Permission. Thanks!
scratchys.ma is offline   Reply With Quote
Old 03-03-2008, 07:22 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's possible, that's where mine was, and that's where the new one (installed Nov 07) is now.
(My land is the same way, long and narrow, brook on one side, driveway on the other)
I am not a septic engineer, I am just saying it is possible.
Only a septic system engineer can give you an exact answer, it it involves seeing the actual plot.
- Build Well -
Old 03-03-2008, 07:33 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,...
Aside from whatever Codes,+ Rules there are in the area you wish to build in,....
The only real Common Sense requirements for a Septic system is,...
That it's Downhill from the house,+ As far away,+ preferably Downhill from your Well,... If Applicable....
Bondo is online now   Reply With Quote
drive over septic tank? stallinc Plumbing 23 11-18-2012 09:32 AM
40s home still on Septic Tank? Inspection? twilightcall Plumbing 4 01-11-2008 07:35 AM
Septic holding Tank Settled phillyd2 Plumbing 7 10-17-2007 12:33 PM
Magnolia tree + septic tank question/problem Jemo General Discussion 5 01-18-2007 10:08 AM
Foundation over abandoned septic tank handyman923 Building & Construction 2 09-29-2005 08:12 PM
