Old 07-25-2007, 10:34 AM   #1
Question
Where to insulate in basement...?
Hello All!
I am days away from installing insulation in my basement finishing project. I live in a duplex, so one wall of the beasement is shared with the adjoining house.
I am planning on installing insulation (R-13) in the stud cavities along the exterior walls (walls which exterior surface contacts earth, all walls are poured concrete). Along the shared wall, the builder conveniently located the furnace and hot water heater, so I simply built a long wall the length of the basement (with bifold door openings to provide access) to enclose the mechanicals and provide storage. The distance between this wall and the shared wall is about 5 feet from inside edge of framed wall to shared wall. My question is, should I insulate the stud cavities of this wall as well? It is basically an interior wall like any other wall that separated two rooms above grade. The ceiling, which I am drywalling is also insulated.
Thanks for any advice!!
DIY4EVER is offline   Reply With Quote
Old 07-25-2007, 07:14 PM   #2
Custom Cabinet Maker
DIY: Shure hope you installed Louvered bi-fold doors! That furnace needs air to breathe
skymaster is offline   Reply With Quote
Old 07-25-2007, 07:35 PM   #3
Remodeler
MinConst's Avatar
I would insulate the wall before the hwh and furnace. No sense in waisting the heat they put out in the winter if you live in a cold climate area. And I agree with the louvers. They a needed.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 07-25-2007, 09:12 PM   #4
concretemasonry's Avatar
Insulating interior walls is a waste of money in the end since the heat is escaping into the house. Especially true with louvered doors.
If you want to save some money use a fresh air intake ducted to the furnace. - No sense in burning heated air and sucking cold into the rest of the house to make up the heated air burned.
concretemasonry is offline   Reply With Quote
Old 07-26-2007, 08:12 AM   #5
I have a double set of 36" bifold doors going directly, smack dab in front of the furnace and water heater for combustion air. The basement area is ~600 sq. ft. so I think this will suffice. Thanks or the input.
I was thinking along the lines of concrete masonry......
Concrete....what would be involved in running the fresh air intake....does it require cutting a hole to the outside?
Old 07-27-2007, 01:33 PM   #6
Insulating interior walls is a money wasted big time bcs the heat is getting the house.true mainly with lowered doors.
HiFi is offline   Reply With Quote
Necessary to insulate basement ceiling between joists? yummy mummy Building & Construction 12 02-07-2009 12:19 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
How do you insulate an old stone basement? hydepark General Discussion 6 08-08-2007 09:35 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
