-   -   Where to insulate in basement...? (http://www.diychatroom.com/f19/where-insulate-basement-10151/)
DIY4EVER 07-25-2007 10:34 AM
Hello All!
I am days away from installing insulation in my basement finishing project. I live in a duplex, so one wall of the beasement is shared with the adjoining house.
I am planning on installing insulation (R-13) in the stud cavities along the exterior walls (walls which exterior surface contacts earth, all walls are poured concrete). Along the shared wall, the builder conveniently located the furnace and hot water heater, so I simply built a long wall the length of the basement (with bifold door openings to provide access) to enclose the mechanicals and provide storage. The distance between this wall and the shared wall is about 5 feet from inside edge of framed wall to shared wall. My question is, should I insulate the stud cavities of this wall as well? It is basically an interior wall like any other wall that separated two rooms above grade. The ceiling, which I am drywalling is also insulated.
Thanks for any advice!!:)
skymaster 07-25-2007 07:14 PM
DIY: Shure hope you installed Louvered bi-fold doors! That furnace needs air to breathe:eek::yes:
MinConst 07-25-2007 07:35 PM
I would insulate the wall before the hwh and furnace. No sense in waisting the heat they put out in the winter if you live in a cold climate area. And I agree with the louvers. They a needed.
concretemasonry 07-25-2007 09:12 PM
Insulating interior walls is a waste of money in the end since the heat is escaping into the house. Especially true with louvered doors.
If you want to save some money use a fresh air intake ducted to the furnace. - No sense in burning heated air and sucking cold into the rest of the house to make up the heated air burned.
DIY4EVER 07-26-2007 08:12 AM
I have a double set of 36" bifold doors going directly, smack dab in front of the furnace and water heater for combustion air. The basement area is ~600 sq. ft. so I think this will suffice. Thanks or the input.
I was thinking along the lines of concrete masonry......
Concrete....what would be involved in running the fresh air intake....does it require cutting a hole to the outside?
HiFi 07-27-2007 01:33 PM
Insulating interior walls is a money wasted big time bcs the heat is getting the house.true mainly with lowered doors.
