Where To Get Support Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2007, 11:10 PM   #1
Rewards Points: 150
where to get support beams
I have a steel support beam that is all rusted out. I need to replace it but don't really know where to buy such a thing.
What sort of weight handling are we talking here, it's one of I think 4 beams, about a 44foot stretch. It's rusted to the point of no support. When I put the new one in, should I jack it up a bit to apply support?
elementx440 is offline   Reply With Quote
Old 03-06-2007, 06:50 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Unless the old beam has allowed sagging to occur, then leave it where it is and jack tight for support. If you jack it up a 'little', that should only be for the removal process of the rusted beam...
Good Luck
- Build Well -
Old 03-21-2007, 11:07 AM   #3
Rewards Points: 150
So who sells this sort of thing?
Old 03-21-2007, 05:58 PM   #4
http://www.thomasnet.com/products/st...3634003-1.html
Also, look around in your own area for similar steel companies...
- Build Well -
Old 03-21-2007, 06:08 PM   #5
Rewards Points: 150
I have I-beams that were installed to hold back the bowing foundation walls. They'll be of no use after the repair, could I use something like this?
Old 03-21-2007, 06:19 PM   #6
It all depends on their girth and span for the structural load that you want them to carry...
- Build Well -
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-20-2011 12:58 AM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 12:03 PM
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 12:15 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
help with support beams on porch falcon802 Carpentry 3 06-24-2006 11:00 AM
