Where To Find Correct Polyurethane Caulk For Foundation Cold Joint? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 05:14 PM   #1
Rewards Points: 1,444
Where to find correct polyurethane caulk for foundation cold joint?
I know polyurethane caulk is considered a good choice for sealing a foundation cold joint where the floor meets the wall. All I can find at Home Depot is polyurethane adhesive caulk. Will that work and is it the same? Most sites say to not use outdoor caulk because it will cause air quality problems and this caulk definately says not to breathe the vapors. Any help would be greatly appreciated. Thanks.
mikegp is offline   Reply With Quote
Old 07-17-2011, 05:45 PM   #2
try a regular building supply place if you still have any near you.
Old 07-17-2011, 05:48 PM   #3
Do you know of a specific brand so I can search/call around?
Old 07-17-2011, 06:17 PM   #4
NACE Coating Inspector
mustangmike3789's Avatar
http://www.tremcosealants.com/commer...asp?category=1 hope this helps.
mustangmike3789 is offline   Reply With Quote
Old 07-17-2011, 06:22 PM   #5
I saw that when I was doing my google searching. I was hoping to find something that is carried in stores. I'd prefer to buy it locally. Thanks though.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Help - can't find the correct low voltage lighting transformer Sherm Electrical 3 03-24-2011 10:21 PM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Is it difficult to find the correct vertical wood siding? darsunt Building & Construction 2 11-25-2009 07:46 AM
