Old 07-17-2009, 07:00 PM   #1
Where to caulk and seal where tile meets tile in bathroom?
Newly tiled floor, tile baseboard, wall behind vanity and toilet, bathtub/shower surround - where to caulk and seal?
Where the floor tiles meet the wall tiles?
The corner where the walls meet in the tub/shower?
These areas are grouted - and I see where the grout manufacturer makes color matched sealant in a tube. Use this? Or clear silicon? or nothing?
Thanks!
Old 07-19-2009, 10:35 AM   #2
anyone?
Old 07-19-2009, 11:31 AM   #3
I would caulk where the walls meet. You could caulk where the floor meets the wall but I wouldn't worry about it. If it starts to crack then caulk it. I would use the grout coloured caulking. It would look the best. Since it's already grouted there is a slight chance you will see the crack in the corner with clear caulking. Make sure you use a silicon caulking though.
joel v. is offline   Reply With Quote
Old 07-19-2009, 12:18 PM   #4
I always caulk where walls meet as they have a consistant tendency to move which opens a crack with grout. I haven't caulked where the floor and wall meet and have not noticed any issues in the area.
I generally use a 100% silicone caulk as many grout colored caulks are, "sanded",and few match the grout color picked by the customer.
It's sort of a best case scenario, where you try to match the colors as close as possible.
Ron
Old 07-20-2009, 03:04 AM   #5
Thanks!!
Should I seal where wood trim meets the brick? megan81 Building & Construction 1 07-01-2008 01:40 PM
What roofing caulk is the best to seal flashing by chimney? twilightcall Roofing 1 05-13-2008 09:07 PM
Best bathroom caulk Richo Plumbing 5 01-22-2008 06:01 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 03:02 PM
