Where To Caulk In A Bathroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 06:58 AM   #1
Where to caulk in a Bathroom
Hey guys,
So I am moving into my new house!
It was a flip and the majority of the work looks great.
However it looks like no caulk was used anywhere…
So a few questions:
1. What areas should have caulk and what type of caulk should be used?
2. For the corners of the shower (tiled all the way up) the grout is already cracking like crazy. What is the best way to remove the grout and apply the silicone caulking?
3. Any tips on getting a nice look to the caulk? (nice even distribution)
As always thanks and let me know if any clarification is needed!
DownRiverGuy is offline   Reply With Quote
Old 03-02-2011, 07:58 AM   #2
Here are a couple links to some info on caulk and how/where to put it etc
As for the grout cracking, I have never dealt with that personally but I would guess water has penetrated it and is causing the issue. That would need to be addressed first!
Hope this helps a little.
Fantastic is offline   Reply With Quote
Old 03-02-2011, 09:32 AM   #3
Rewards Points: 558
1) The areas that should be caulked are horizontal and vertical seams along your shower door if you have one. Along the outside base of your tub and along edge of your tile by using a “tub and tile caulk like Kwik Seal Tub & Tile Adhesive Caulk which dries in 15 minutes is mildew resistant and if needed is also paintable.
2) For your corners which are already grouted, you will have to remove all grout with a grout saw or other tool in order to apply your caulk.
3) The way to make your caulking job look nice is to use painters tape by applying one peace above the gap and another below the gap on tub with a space between 3/8’’ – ¼’’ apart and apply the caulking into gap and then spread the caulk with a wet finger to get a nice even line. When this is complete, remove the tape immediately and you will have a nice professional looking caulk line.
epson is offline   Reply With Quote
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 07:38 AM
Best Bathroom Caulk for 2010? SimpleJack Plumbing 9 04-01-2010 04:12 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
removal of old hard bathroom caulk pop2pop General DIY Discussions 1 02-25-2005 01:11 AM
