When To Replace Rotted Stud Vs. Epoxy - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 11:23 AM   #1
When to replace rotted stud vs. epoxy
Hi, Due to 2nd floor bathroom flood (problem was resolved) I removed drywal ceiling below bathroom. Upon inspection I saw rot in 4" x 4" flooring under corner of bathtub probably due to water dripping from bathtub corner edge. I dremel the rot away but then ran into 2nd floor wall stud (horizontal) next to rotted floor. Looks like the horizontal stud is rotted 6" and discolored another 6 " on either side. Top side of horizontal stud looks good as well as veritical studs standing on top of the rotted horizontal stud.
The other corner had a problem 3 years ago when I remodel and I replaced floor and expoxy stud. I probably should have replaced stud
Bathroom floor (tile / cement board) and under tub looks good except the corners.
I could open non bathroom side of the wall to look at it more detail.
When do you expoy vs. rip and replace stud?
I can send pictures later tonight.
Ken
ken57 is offline   Reply With Quote
Old 11-07-2011, 09:40 PM   #2
Rewards Points: 1,092
My opinion is to replace any rot w/ fresh boards if at all possible. Gluing marginal material is, I think, asking for failure at some later time. By "horizontal studs" do you mean floor joists? Pics would be great.
Old 11-08-2011, 12:53 AM   #3
liscenced electrician
Rewards Points: 538
Rot should be replaced whenever possible. I don't think epoxy would add any strength, so if its rotten enough to need epoxy, it probably bad enough to need replaced
jimmy21 is offline   Reply With Quote
Old 11-08-2011, 05:45 AM   #4
DIY staff
Rewards Points: 7,174
Studs are $2.60 each---Epoxy about $20.00 No question about what I'd do.
Old 11-08-2011, 06:48 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Studs are wood
Epoxy is Bondo.........
tcleve4911 is offline   Reply With Quote
Epoxy Questions bsmith95610 Flooring 11 04-02-2011 03:41 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 08:24 PM
