-   -   When to replace rotted stud vs. epoxy (http://www.diychatroom.com/f19/when-replace-rotted-stud-vs-epoxy-122659/)
ken57 11-07-2011 11:23 AM
Hi, Due to 2nd floor bathroom flood (problem was resolved) I removed drywal ceiling below bathroom. Upon inspection I saw rot in 4" x 4" flooring under corner of bathtub probably due to water dripping from bathtub corner edge. I dremel the rot away but then ran into 2nd floor wall stud (horizontal) next to rotted floor. Looks like the horizontal stud is rotted 6" and discolored another 6 " on either side. Top side of horizontal stud looks good as well as veritical studs standing on top of the rotted horizontal stud.
The other corner had a problem 3 years ago when I remodel and I replaced floor and expoxy stud. I probably should have replaced stud
Bathroom floor (tile / cement board) and under tub looks good except the corners.
I could open non bathroom side of the wall to look at it more detail.
When do you expoy vs. rip and replace stud?
I can send pictures later tonight.
Ken
jklingel 11-07-2011 09:40 PM
My opinion is to replace any rot w/ fresh boards if at all possible. Gluing marginal material is, I think, asking for failure at some later time. By "horizontal studs" do you mean floor joists? Pics would be great.
jimmy21 11-08-2011 12:53 AM
39 Attachment(s)
Rot should be replaced whenever possible. I don't think epoxy would add any strength, so if its rotten enough to need epoxy, it probably bad enough to need replaced
oh'mike 11-08-2011 05:45 AM
Studs are $2.60 each---Epoxy about $20.00 No question about what I'd do.
tcleve4911 11-08-2011 06:48 AM
Studs are wood
Epoxy is Bondo.........
