When To Install Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 12:50 PM   #1
New Home Owner
When to install Doors
I am finishing my basement, I've got all the stud work and electrical done, I've got most of the drywall done, but not finished. I still have to do the ceiling and tape and mud portions. About 1/2 has the tape and mud done. I received the doors for the project and wanted to know when I should install them. They came before I had all of the drywall taped and mudded and are leaned up against one wall that I can't get to know until I install some of the doors. I could use some suggestions as to what to do first.......
DandHJohn is offline   Reply With Quote
Old 09-18-2010, 04:12 PM   #2
kwikfishron's Avatar
Rewards Points: 576
You can do whatever you want but I don’t want my doors any ware near the mud mess.
kwikfishron is online now   Reply With Quote
Old 09-18-2010, 04:14 PM   #3
DIY staff
Rewards Points: 7,174
Doors and trim are usually installed last--after the drywall is done,primed and the first coat of paint is complete.
Before carpet--easier after tile,if you are tiling the floors.---Mike---
I hope I answered the question.
kwikfishron (09-18-2010)
Old 09-18-2010, 11:23 PM   #4
NE78FJ40's Avatar
Rewards Points: 18
I am to the point where I am finishing up all the tiling. My question is when you installed the base trim, how much of a gap to you use between the concrete and the trim? The carpet is going on concrete and we want to use a thicker padding. Also do you leave that same gap at the base of the door and the bottom of the door frame?
NE78FJ40 is offline   Reply With Quote
Old 09-19-2010, 12:53 AM   #5
jlhaslip's Avatar
Rewards Points: 2,074
Depends on the carpet. Some are thicker and need about 5/8" from the concrete. Others are thinner and only need 3/8 or so. Contact your carpet supplier and speak with the installer, if possible.
The door jambs should be spaced off the floor the same amount, except on tile or lino where the jamb is set down on top of those finishes.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 09-19-2010, 04:40 AM   #6
Rewards Points: 1,016
I would suggest 1/2".
The Following 2 Users Say Thank You to vsheetz For This Useful Post:
BigJim (09-19-2010), oh'mike (09-19-2010)
Tags
basement finishing , doors
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 09:14 AM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 03:48 PM
How soon can I install Masonite doors after sheetrock? cej22 Carpentry 6 07-09-2009 08:11 AM
When to Install Pre-Hung Interior Doors For New Construction Hages Carpentry 5 03-01-2007 09:34 PM
